  SoarerCentral * Kiwi Corner * Parts * Spider gears Previous Previous    Next Next
Chris Stephenson
west harbour
soarer 4.0 v8
Reg: 08-2008
Saturday, March 31, 2012 - 04:38 pm, by:  Chris Stephenson (Hooch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi all i am just wanting to know if anybody can tell me where i mite be able to find a new set of spider gears for my LSD....had to get an open diff as a replacement so have decided to re build my old diff
Victoria (The Nazi State)
Pretty Red Thing and The Black Rattler
Saturday, March 31, 2012 - 07:38 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What type of LSD?? I'd suggest the manufacturer of the diff might be a place to start.
Chris Stephenson
west harbour
soarer 4.0 v8
Reg: 08-2008
Sunday, April 01, 2012 - 08:18 pm, by:  Chris Stephenson (Hooch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
it is the factory LSD and i dont want to go through Toyota lol
Monday, April 02, 2012 - 10:22 am, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Factory LSD doesn't have spider gears.
Andrew Marshall
SC400
Reg: 06-2011
Friday, November 23, 2012 - 10:10 pm, by:  Andrew Marshall (The_rooman) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Gidday Dan. If the Factory LSD doesn't have spider gears, then why does the clunk happen on the left rear wheel? I have had it to my mechanic, who pulled out his manual on the diff, which showed a spider gearing between the 2 springs and the plates which make up the LSD. Do you know what it is then that needs replacing? He is happy to rebuild it if I can source the parts, which appear to be these bits, not the crown or pinion gears. Thanks
Friday, November 23, 2012 - 11:59 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Factory LSD doesn't have springs and plates either.
Sounds like he's shown you a picture of a clutch type LSD, wheras the factory LSD's are a TORSEN type.
AFAIK Toyota is the only supplier of parts for these, and the diff centre is a non serviceable unit.
If there's a clunk I'd be more inclined to think a CV shaft, or a hub issue.
Andrew Marshall
SC400
Reg: 06-2011
Saturday, November 24, 2012 - 10:57 am, by:  Andrew Marshall (The_rooman) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Dan. That sounds more like it as the clunk appears to come from that area, and I can feel a pulsing through the car when we had it up on the hoist and I had it in gear and the wheels spinning. I could actually feel a pulsing through the frame of the car. If you hear hooves, think horses, not zebras, which would be the motto here. He is an old bloke, with data to match. I think the diff he showed me was out of his Land cruiser, which would explain the issue. So what's the diagnostic for this? A hint would be great. Cheers.
