  SoarerCentral * Kiwi Corner * Parts * Air compressor drier Previous Previous    Next Next
Rod Quaife
Waikato
Monday, July 15, 2013 - 06:37 pm, by:  Rod Quaife (Rod_quaife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does anyone know anything about the suspension airbag compressor drier. I saw somewhere that the silicon in the drier should be changed, is this easy to do or do you need to replace drier
Dave Hart
Waikato
UZZ32
Monday, July 15, 2013 - 07:09 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not knowledgable about the work involved but all our silica gel has been replaced with a less dangerous desiccant so you should check before exposing yourself.
Good luck Rod.
