  SoarerCentral * Kiwi Corner * Parts * JZZ30 Radiator Previous Previous    Next Next
Tim Hutchings
Lower Hutt
JZZ30 Single Turbo
Reg: 01-2008
Monday, August 26, 2013 - 10:20 am, by:  Tim Hutchings (One_jay_zed) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys, I had a catastrophe involving a jack failing on me and now I need a new radiator (DAMMIT!!!).
Who knows if the 1UZ/2JZ model rads will fit? I'm not fussy, I just need my car going asap, any help would be greatly appreciated!
Contact me here or 022 096 9486
Cheers!
Blake Gloyn
manawatu
soarer JZZ30 TT
Monday, August 26, 2013 - 10:29 am, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the jzz31 will fit. not sure about the v8. Evan will know.
Monday, August 26, 2013 - 11:24 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They look very different out of the vehicle - I'm pretty sure a 1UZ rad would be next to useless. The 2JZ radiator is also different looking - so I'd not risk it.
Maybe look at taking it to a specialist and getting it re-cored? I had my 2JZ rad re-cored about 4 or 5 years ago (no idea what it cost as it was an insurance job after accident damage) and it's been brilliant.
Mind you sounds like yours might be too badly damaged around the bottom?
Andrew Poh
Waitakere
96 Soarer 2JZ-GE
Reg: 08-2008
Monday, August 26, 2013 - 02:43 pm, by:  Andrew Poh (Drewpoh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just find someone with a welder and make up a custom bracket with the old ones, and then find some hoses that will plumb it all back together.
I've always found this to be easy fix for radiators.
Evan Kaio
Quiwiland NZ
'91 UZZ31. 92 TT
Reg: 01-2007
Monday, August 26, 2013 - 04:58 pm, by:  Evan Kaio (Knave) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Supra JZA will fit, just sits lower.
I have a spare JZZ30 radiator.
Tim Hutchings
Lower Hutt
JZZ30 Single Turbo
Reg: 01-2008
Tuesday, August 27, 2013 - 05:53 am, by:  Tim Hutchings (One_jay_zed) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What sort of price Evan? I could drop your exhaust off at the same time (yeah it's still stored away).
Mark Donovan
Auckland
Tuesday, August 27, 2013 - 06:52 am, by:  Mark Donovan (Mark_donovan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tim - I hope you'll be using axle stands as well from now on. Stay safe.
