  SoarerCentral * Kiwi Corner * Parts * WTD: JZZ30 Soarer window motor + inside door handle Previous Previous    Next Next
Jesse Pieterse
Auckland
Soarer JZZ31
Reg: 04-2013
Sunday, November 16, 2014 - 09:15 am, by:  Jesse Pieterse (Driftmonkey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Auckland is preferred but no big deal if postage is needed.
Cheers,
Jesse 022 439 0552
Jesse Pieterse
Auckland
Soarer JZZ31
Reg: 04-2013
Sunday, November 16, 2014 - 09:16 am, by:  Jesse Pieterse (Driftmonkey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
passenger side window is stuck open and I need a motor for it asap.. been raining way too much lately.. seat is soaked.
Blake Gloyn
manawatu
soarer JZZ30 TT
Sunday, November 16, 2014 - 12:29 pm, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
is it definitely the motor, as opposed to the more common regulator fault?
BTW I should have either/both available next week.
Jesse Pieterse
Auckland
Soarer JZZ31
Reg: 04-2013
Sunday, November 16, 2014 - 08:42 pm, by:  Jesse Pieterse (Driftmonkey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not 100% sure. Window was working, only intermittantly then one day died.
Jesse Pieterse
Auckland
Soarer JZZ31
Reg: 04-2013
Tuesday, December 02, 2014 - 07:36 am, by:  Jesse Pieterse (Driftmonkey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Got a regulator still, Blake? How much you want for It?
Jesse Pieterse
Auckland
Soarer JZZ31
Reg: 04-2013
Tuesday, December 02, 2014 - 08:08 pm, by:  Jesse Pieterse (Driftmonkey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
b
Blake Gloyn
manawatu
soarer JZZ30 TT
Wednesday, December 03, 2014 - 06:52 am, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah i have got a reg. will test it to make sure it is working, then send it up to you. you pay postage.
Jesse Pieterse
Auckland
Soarer JZZ31
Reg: 04-2013
Wednesday, December 03, 2014 - 07:32 am, by:  Jesse Pieterse (Driftmonkey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Beauty! Text me bank details on 022 439 0552. Much appreciated :-) will be good to finally have a door card back on after 3 weeks without one haha.
Jesse Pieterse
Auckland
Soarer JZZ31
Reg: 04-2013
Sunday, December 14, 2014 - 10:25 pm, by:  Jesse Pieterse (Driftmonkey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone got an inside door handle for passenger side?? and a regulator? In need of them for warrant... please & thank you
Auckland
95 UZZ31 with R154
Reg: 03-2009
Tuesday, December 16, 2014 - 04:50 am, by:  James Johnson (Jimbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Passenger inside door handle as in the black bit you pull to open the door?
Jesse Pieterse
Auckland
Soarer JZZ31
Reg: 04-2013
Tuesday, December 16, 2014 - 07:39 am, by:  Jesse Pieterse (Driftmonkey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Correct
Ben Lipman
Soarer TT manual, plus TT track car, plus a spare shell
Wednesday, December 17, 2014 - 09:16 pm, by:  Ben Lipman (Ben12a) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jesse, after braking a couple of second hand door handles (all passenger - go figure) I purchased new from Toyota for about $80 and have never had another issue. That was Toyota Australia's 'bugger you for buying an import' pricing to, so NZ should be cheaper.
Jesse Pieterse
Auckland
Soarer JZZ31
Reg: 04-2013
Saturday, December 27, 2014 - 12:21 pm, by:  Jesse Pieterse (Driftmonkey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
b
