  SoarerCentral * Kiwi Corner * Parts * Frost plugs Previous Previous    Next Next
Rod Quaife
Waikato
Tuesday, June 02, 2015 - 02:17 pm, by:  Rod Quaife (Rod_quaife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi everyone, Getting cam belt done again shortly. Is there any frost plugs on front of engine which should be replaced whilst everything is off. Replacing all other usual parts as well. Thanks
Dave Rose
wa
UZZ31 / ML320 CDI
Tuesday, June 02, 2015 - 03:27 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rod would not bother changing front core plugs (the ones at the back of engine have been known to leak ) but i would change water pump while its easy to get to.
Rod Quaife
Waikato
Tuesday, June 02, 2015 - 04:05 pm, by:  Rod Quaife (Rod_quaife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok thanks Dave. Just thought I might do them whilst all bits off but you reckon don't bother. Yes doing water pump and seals and all rest of gear.
Dave Rose
wa
UZZ31 / ML320 CDI
Tuesday, June 02, 2015 - 06:03 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And Toyota red coolant !
UZZ32 No.32 & JZZ31 3.0GT
Friday, June 05, 2015 - 03:01 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The only seal to really check is the front main oil seal, they can leak. Worth replacing when the timing gear is off.
As does the block plate seal for the coolant below cylinder No.2 on the drivers side
