  SoarerCentral * Kiwi Corner * Parts * Amp Previous Previous    Next Next
Rod Quaife
Waikato
Tuesday, June 02, 2015 - 04:20 pm, by:  Rod Quaife (Rod_quaife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Has anyone got or know of a amp dsp unit for sale. Volume starting to get bit weak on mine. Assume the amp and dsp unit go together. Also,assume you can get amp recapped. Thanks.
Tim Schroeter
V8, V8, V8
Reg: 04-2014
Rating:
Votes: 1 (Vote!)
Tuesday, June 02, 2015 - 10:35 pm, by:  Tim Schroeter (790) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rod, Mike beck in NZ has experience in these things. facebook page is:
Mike's UZZ32 Soarer Restoration - No. 32 / 873
UZZ32 No.32 & JZZ31 3.0GT
Friday, June 05, 2015 - 02:59 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Rod,
Indeed, I bought Dave Harts old UZZ32, the stereo was pretty stuffed. So I decided to give recapping it a go given the trouble they cause.
Probably cost me around $200-250 worth of quality Panasonic and Nichicon caps. DSP, Reciever, Rear amp, CD stacker and Sub amp all got replaced by my self. There must be at least 200 Audio related caps to replace so its no easy task for the novice.
Results are startling, like brand new again loud, clean and powerful.
Rod Quaife
Waikato
Friday, June 05, 2015 - 06:55 pm, by:  Rod Quaife (Rod_quaife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes thanks Mike. Would start with the main amp which is under the changer is it not.
Roland Elliott
uzz32 1uz-fe
Reg: 08-2014
Saturday, June 06, 2015 - 12:22 am, by:  Roland Elliott (Aussie2013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Time consuming but worth it, with quality caps it should last over 20 years or more, They are a well designed circuit and my experience with this Jap stuff is long life ++ and good quality sound.
Saturday, June 06, 2015 - 06:11 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It is Rod. I found the main issue was with the reciever actually, the bigger unit next to the smaller DSP.
After I did the caps the volume came back etc.
Doing the main amp just smoothed the sound out further etc.
Tim Schroeter
V8, V8, V8
Reg: 04-2014
Saturday, June 06, 2015 - 07:49 am, by:  Tim Schroeter (790) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Like 80s 90s Hi Fi systems. Simple circutry, high power & quality. Mike aren't you glad that you didn't replace the system with aftermarket?
I'll do the same as you did. Pull the gear out of 310, recap it & refit into 790.
Monday, June 08, 2015 - 11:14 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Agreeed, I wouldnt have bothered changing to an aftermarket and loosing the original parts / features like many UZZ31/32 owners have done with their EMV systems.
Besides I'd need to spend a couple of grand on an above average system to satisfy my OCD nature.
Still, I'm more interested in the cars mechanical performance anyhow so I'd never go that far!
Rod Quaife
Waikato
Saturday, June 20, 2015 - 01:46 pm, by:  Rod Quaife (Rod_quaife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Mike where did you get your capacitors from when you replaced the radio and dap unit. Might have a try at doing the dap unit myself having looked at tutorials on replacing caps. I see that the brands you used seems to be best with lots of warnings of imitation brands about.
Monday, June 22, 2015 - 08:59 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
RS Online is the way to go Rod.
Yeah If you feel confident doing it give it a go. I think there's about 50 caps in the DSP unit. Some are bi polar so take note of that.
More inside the shielded unit within but I didn't get around to replacing them.
Tom Richards
Monday, June 22, 2015 - 10:00 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
rod, if you have not worked on multi layered PCB's I would get someone with experience to do the job.
Over heating the PCB will stuff it beyond repair. Removing the old component is the tricky bit.
Tuesday, June 23, 2015 - 07:11 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
^ Word. Keeping temps down is the key. Also being mindful of static discharge too.
I'm always extra careful when working near ICs, I stop work if they get over 50 deg c in a 20 deg room when de-soldering legs in close proximity.
The uses of IR heat guns are endless :-)
If you want I could look at doing this work for you Rod?
Rod Quaife
Waikato
Tuesday, June 23, 2015 - 03:22 pm, by:  Rod Quaife (Rod_quaife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sure thing Mike I would appreciate that. I am pretty sure it's the dsp unit as when it's switched in it cuts out the passenger side speakers. When off get sound back again but with weak volume. Wen the dsp switched on the drivers side speakers go very loud and passengers speakers go,quiet. All speakers go with radio going. Just seems to be when Dsp switched in when playing CDs. Can you give me a price Mike to do the dap unit with the good caps you use. Thanks.
Rod Quaife
Waikato
Tuesday, June 23, 2015 - 03:35 pm, by:  Rod Quaife (Rod_quaife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You can pm me Mike. e mail address on my profile. thanks.
Wednesday, June 24, 2015 - 01:04 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Emailed you Rod. :-)
