  SoarerCentral * Kiwi Corner * General Chat * Outer tierod ends Previous Previous    Next Next
Chris Stephenson
Ranui
soarer 4.0 v8
Reg: 08-2008
Wednesday, June 17, 2020 - 04:07 pm, by:  Chris Stephenson (Hooch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just wondering if the 91 v8 soarer has the same tierod ends as the jza80 supra or are they slightly different?
Steve Gorman
Thursday, June 18, 2020 - 03:02 pm, by:  Steve Gorman (Steve_gorman) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I used toyodiy.com and part number 4546019235 and it gave the following result
05/1993-07/2002
TOYOTA SUPRA
JZA80
45-05: FRONT STEERING GEAR & LINK
General
05/1993-04/1996
TOYOTA SUPRA
JZA80
Japan
05/1991-11/2000
TOYOTA SOARER
JZZ3*,UZZ3*
if you want see a diagram use
https://partsouq.com/ and enter the part number and you should see the listing.
I use these sites frequently as Toyota is a master at using parts in various models.
