  SoarerCentral * Kiwi Corner * Parts * Soarer parts for sale. Previous Previous    Next Next
Fred Fuchs
UZZ32
Reg: 02-1998
Friday, June 30, 2006 - 10:48 pm, by:  Fred Fuchs (Bigmac) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hello All,
Ive been a soarer owner for a while and at one stage owning a 31 and a 32 for a year.Just the 32 now but with the 31 options that the 32 didnt have plus a few more.
The main purpose is i have some bits for sale so if anyone is in need pls let me know.
1.Front brake setup - calapiers and rotors
2.Front nose with bottom lip in green,the sterofoam backing and aluminium bar.
3.Subwoofer setup that sits on the rear parcel shelf.
4.rear parcel shelf
5.Some other ecu modules.
cheers everyone.
Saturday, July 01, 2006 - 02:50 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Noice!, and a very long term member I see
Hi Fred, and welcome back
Fred Fuchs
NZ
UZZ32
Reg: 02-1998
Saturday, July 01, 2006 - 06:30 pm, by:  Fred Fuchs (Bigmac) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Don,
Haydens site has certainly had an extreme makeover since the last time i saw it!!
Saturday, July 01, 2006 - 06:51 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ain't that the truth
Mark Donovan
Auckland
Soarer V8 Limited
Saturday, July 01, 2006 - 08:28 pm, by:  Mark Donovan (Mark_donovan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Fred- sent you an email. Would be great to have another Kiwi on the board here. I'd imagine your Soarer is probably one of the more modified models in NZ in terms of the electrical work you did- did you actually get the Soarer phone option working?
Fred Fuchs
NZ
UZZ32
Reg: 02-1998
Sunday, July 02, 2006 - 04:46 pm, by:  Fred Fuchs (Bigmac) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Mark,
Looking back now i did probably spend too much on the car but owning 2 for a year made it alot easier.As most will know only about 862 UZZ32s were made and im basing this on the Toyota parts cds i have.Options like sunroof,front parking antenna and heated seats werent available so out they came from the UZZ31 and into the 32.I have also put in the rear air purification system that sits ontop of the fuel tank.The air goes in one rear speaker cover and out the other.Had to get those and a new rear parcel shelf without the sub hole from Japan.Most of the wiring is in the car for it and the switch sits up underneath where the remote locking system switch is located.Regarding the phone,the setup is based on the old motorola flip phone so thats all sitting in the box.I have been thinking however to mount the steering wheel controller and interfacing it to my nokia setup.
Im not spending anymore money on the car except the usual stuff.
One thing i learnt last week was about an annoying knock.For a number of years ive had an annoying knock that felt like it was under the drivers seats everytime i went around a round about.Spend hunderds in time for people to tell me they cant fix it.The other week as the car was being reversed off a hoist the mechanic touched the brakes and the calapier continued going and when he let go it spung back up.The other side did it too.I got the bottom arm bushes on both sides done (they sent the arms away to Hamilton) and when the car was back on its feet the calapiers were solid and the knock was gone.Im amazed i got so many warrants like this and that my wheel alignment stayed so accurate.
Well thats me 2 cents worth today.
Fred Fuchs
NZ
UZZ32
Reg: 02-1998
Friday, July 14, 2006 - 03:27 pm, by:  Fred Fuchs (Bigmac) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Update on parts.
1.Set of rear lights
2.door lock ecu
3.Subwoofer amp
4.Subwoofer speaker
Thanks
Matt Gill
Saturday, July 15, 2006 - 12:12 pm, by:  Matt Gill (Drifter4ag) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey man,
i have the whole subwoofer /rear speaker setup for sale including the amp if you are keen email me at
drifter1jz@garagedori.com.
