  SoarerCentral * Bodywork and Exterior * Pic Request: Caliper Decals Previous Previous    Next Next
Simon Triantafillou
Soarer Turbo
Tuesday, August 30, 2005 - 02:00 pm, by:  Simon Triantafillou (Soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi all,
Just needing the help of anyone who already has a set of either Lexus or Soarer caliper decals (rear). I need a photo to sort out how the rear ones are designed so I can create a proper template for decals. If anyone has any photos, please forward them through to my email account so I may see how the original design looked.
Reason I ask is that there is very limited space on the rear caliper and can't figure out how the old decals were designed.
Thanks.
Ollie Ernst
Soarer V8 Limited
Tuesday, August 30, 2005 - 02:24 pm, by:  Ollie Ernst (Oli_g) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Simon........If nobody else responds by the time I get home I'll scan mine. I've got a set in the cupboard that I got of Gav Watson and haven't put on the car yet.
Simon Triantafillou
Soarer Turbo
Tuesday, August 30, 2005 - 03:35 pm, by:  Simon Triantafillou (Soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Ollie, that'd be much appreciated, and I was actually after a pic of Gavin's originals too.
Ollie Ernst
Soarer V8 Limited
Tuesday, August 30, 2005 - 04:34 pm, by:  Ollie Ernst (Oli_g) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Here you go Simon. Unfortunately they're white so a bit hard to see but I hope it's a help. I've scanned one front and one rear caliper sticker.
Ollie Ernst
Soarer V8 Limited
Tuesday, August 30, 2005 - 04:39 pm, by:  Ollie Ernst (Oli_g) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Simon Triantafillou
Soarer Turbo
Tuesday, August 30, 2005 - 05:32 pm, by:  Simon Triantafillou (Soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That's fine Ollie. I had a look at my rear caliper and couldn't figure out where they were supposed to stick to. So little usable real estate on them for stickers.
David Wilson
Tuesday, August 30, 2005 - 05:58 pm, by:  David Wilson (Davieeeee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Simon,
I had a set ages ago, basically the front said lexus whereas the back was just a small "L" logo since there wasnt much room back there
Marshall Hughes
Tuesday, August 30, 2005 - 06:55 pm, by:  Marshall Hughes (Sierra055) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Simon, I sent you an email on Saturday with the art for the Lexus ones. Did you get it?
Simon Triantafillou
Soarer Turbo
Wednesday, August 31, 2005 - 09:38 am, by:  Simon Triantafillou (Soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks guys.
Marshall, I have emailed you back, thankyou :-)
Chris Fonte
2.5 TT
Friday, October 07, 2005 - 11:04 am, by:  Chris Fonte (Luvbuds) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What programs do you use do make your stickers/decals & I been looking into this myself.
Simon Triantafillou
Soarer Turbo
Friday, October 07, 2005 - 12:45 pm, by:  Simon Triantafillou (Soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Illustrator is usually the tool of choice. Need to be able to manipulate vectors.
