  SoarerCentral * Bodywork and Exterior * Rear Washer Previous Previous    Next Next
Robert Millham
Monday, September 12, 2005 - 06:27 pm, by:  Robert Millham (Lexus_boi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys.
My rear washer only squirts a few drops, my fronts washer works fine, Is there another tank for the rear washer?
Monday, September 12, 2005 - 06:30 pm, by:  Benny Gammelmark (Oldfield) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
to the site Robert.
I don't have rear washer but someone will be here shortly and explain all (or make silly comments).
The feeding tube or the nozzle could off cause be blocked.
Mustafa Akgul
JZZ30-GTTL Im not a tinkerer!
Monday, September 12, 2005 - 06:52 pm, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
welcome..
the rear washer is supplied from the same tank in the left front of the car..
prolly just blocked nozzle get some thin wire and poke it around in the nozzle..:-)
Taranaki
Monday, September 12, 2005 - 07:35 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Robert.
Get someone to operate the washer, and while the water is dribbling out, poke a pin, needle or piece of fuze wire into the hole.
Give it a good jiggle around in the hole(s) until it sprays out correctly.
Because people don't use the rear one too often it tends to grunge up with car wax, and other general crappola.
Jeff Hogan
Monday, September 12, 2005 - 10:37 pm, by:  Jeff Hogan (Hoges) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
it takes a fair while for the water to actually get to the rear squirter, i sometimes have to hold mine on for about 20-30secs before anything much comes out.
lol neil, in australia we spell it SPELL
Ryan Rankovic
Soarer TT GT-TL
Monday, September 12, 2005 - 11:31 pm, by:  Ryan Rankovic (Ryan1j) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
20 - 30 seconds? mine seems to be pretty much instant.....
Tuesday, September 13, 2005 - 12:27 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Robert, I altered the thread title, "S" isn't really a descriptive title, and I moved it from Articles of Interest to the current Topic area.
Welcome to SC, but can you please use a little more care when starting a thread?
Vinod Param
Soarer V8
Tuesday, September 13, 2005 - 09:20 am, by:  Vinod Param (Vparam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mine is pretty instant on the rear.
BUT the front takes a good 5-10seconds to squirt which is not normal because the wiper starts moving before the water hits the screen.
Taranaki
Tuesday, September 13, 2005 - 09:52 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Neil: Yeah that's what I meant
Jeff: I suspect your in-line anti drain back valve is stuffed or missing
Jeff Hogan
Tuesday, September 13, 2005 - 04:47 pm, by:  Jeff Hogan (Hoges) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
inline anti drain back valve eh...
where would i find this contraption to see if it is indeed buggered?
James Jones
V8 Soarer
Tuesday, September 13, 2005 - 05:02 pm, by:  James Jones (Jones) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
haha, sounds like some mythical device...
but i'm sure it probably actually exists.
Taranaki
Tuesday, September 13, 2005 - 05:31 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Here tis,
Part number is: 85031-30010 VALVE SUB-ASSY,WASHER JZZ30, UZZ3#
Clic de link to see approx where it is in relation to da other bits n' stuff.
http://homepage.ntlworld.com/noctiluca/Soarer/EXtoyota4/localf~1/download/extoyo~1/wwwelc~1.ru/toyot a/deta~103.htm
Sam Schreck
vvt-i JZZ31
Tuesday, September 13, 2005 - 05:36 pm, by:  Sam Schreck (Schreck300) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, I always get wax and stuff in my front ones. I do what Don mentioned..a tiny pin in the end and a little warm water. Good as new mate.
p.s
Jason Kingsmill
UZZ31 Soarer V8
Tuesday, September 13, 2005 - 05:51 pm, by:  Jason Kingsmill (Jason_k) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Robert.
Yeah, it's a one-way valve, much like that you would see in a decent snorkel. A flexible diaphragm that will move in one way when pressure is applied, but when the pressure comes from the opposite side, the diaphragm seals.
Jan Heinrich
UZZ32 No. 312
Tuesday, September 13, 2005 - 06:19 pm, by:  Jan Heinrich (Yarno) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
there is a ball type check valve in the line to the back, it's near the passengers foot well.
I also have 2 washer bottles one dedicated to the front and one for front and back this is standard it is similar to the uzz31 (spare wreck) out the front
Alan Chow
Wednesday, September 14, 2005 - 12:09 pm, by:  Alan Chow (Kfchow) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey you know how you can get those fan spraying ones for the front... can you get an equivilant for the back?
Robert Millham
Wednesday, September 14, 2005 - 05:41 pm, by:  Robert Millham (Lexus_boi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Guys, sorry about the posting title. I'll give those ideas a shot. I will also try to have a few photos of my car with my profile.
