  SoarerCentral * Bodywork and Exterior * Mag Help, offset? supra brakes? Previous Previous    Next Next
Sam Sulley
GT-TL
Sunday, September 18, 2005 - 08:52 pm, by:  Sam Sulley (Ss666x) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i am looking at buying a set of mags
18 x 8 +43
18 x 9 +44
just wondering. they were bought for a supra, but i will be eventually putting supra brakes on the soarer. the dude says that i will need spacers, but that's illegal. Just after some more opinions.
cheers
Mark Paddick
Soarer UZZ31
Sunday, September 18, 2005 - 09:42 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You need approximately 7cm clearance from the brake disc surface to the inner of the wheel, or spoke of the wheel, (or any other bit of the wheel for that matter) in order to fit Supra brakes.
In this case the wheel offset does not have a lot to do with it. It is more a case of the wheel design and how the spokes curve, or don't. Deep dish + supra brakes don't normally mix.
Have a look at the wheels on my profile pic. I don't think the brakes were on the car then but they are now. Those wheels have the best clearance for Supra brakes of any I have ever seen, including factory Supra wheels.
Beware that even factory Supra wheels won't fit a car with big Supra brakes if they weren't off a car with them.
Mark Paddick
Soarer UZZ31
Monday, September 19, 2005 - 05:01 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I will have a set of 17 x8 that fit the Supra brakes for sale on Thurs. Check my profile for pics.
Black/Black JZZ30 VVTi
Monday, September 19, 2005 - 06:32 pm, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sam,
Remember to keep in mind the disk offset as well. Did the wheels come of a 95+ Supra or before? Because if it's from the model before it would've had the same brakes as the TT/Active models.
