  SoarerCentral * Bodywork and Exterior * Locked out? Previous Previous    Next Next
Dave Hart
Not Australia
UZZ32
Friday, October 07, 2005 - 07:08 am, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You're in the middle of nowhere, cell phone and keys are locked inside.
Whats the cheapest option, smash windscreen or door windows to gain access?
Friday, October 07, 2005 - 10:39 am, by:  Daniel Czechowski (Dan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rear quarter window seems the smallest (=cheapest). Or hope u got a non-excess broken windscreen cover and smash that... driving without it would suck tho heheh
Scott Thompson
1jzgte tt
Friday, October 07, 2005 - 12:26 pm, by:  Scott Thompson (Scotty) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
is this a trick question?lol surely you can get a cell phone ,you just got access to the net didnt you ,or ask someone on here to send someone to you eh
Jeff Hogan
Friday, October 07, 2005 - 03:02 pm, by:  Jeff Hogan (Hoges) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i think its a hypothetical situation, like say you are driving on a long trip, and stop for a pee on the side of the rd and accidentally lock yourself out with your phone inside the car. theres noone around to help you so your only option is to break a window to get in.
I have no idea which would be cheaper, but i know the rear quarter window is a whole unit, you cant just replace th glass i dont think. i would go for the passenegers front window, that way u wont get glass on the drivers seat....
Scott Thompson
1jzgte tt
Friday, October 07, 2005 - 04:16 pm, by:  Scott Thompson (Scotty) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
in that case smash the winscreen we replace them for $200,plus you get the wind in your hair while your driving lol
Troy Tappenden
JZZ30 (TT)
Friday, October 07, 2005 - 05:26 pm, by:  Troy Tappenden (Moredhel) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rear quarters are the smallest, but they are also the most expensive. I had a friends think that because it was the smallest it was the cheapest and broke that to get in to his car (Not a Soarer though) and it was the most expensive bit of glass on the car. I would say Windscreen. Easiest to replace, and possibly the cheapest. Breaking a window will mean you need to get it re-tinted when it is replaced, if you have tinting, so that is more money as well.
Dave Hart
Not Australia
UZZ32
Saturday, October 08, 2005 - 08:08 am, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I thought the windscreen would be the cheapest option, not sure of the implications that would crop up though, like driving, broken glass every where.
You'd have to be unlucky to lock yourself out like exiting via the passenger door and turning the switch to lock as you got out.
The other way is as mentioned previously via a dodgy car alarm system, or having a pet in there that knocks the door lock switch.
I thought a door window would be less easiest and costliest to replace.
Best to leave it to the insurance cover and break the windscreen.
UZZ32 V8 Soarer #183
Saturday, October 08, 2005 - 08:37 am, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you do break the windscreen, wind the side windows down and drive slowly to prevent the air pressure popping the back window out. :-)
Saturday, October 08, 2005 - 08:45 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
just drive home in reverse :-)
Saturday, October 08, 2005 - 07:49 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Easy peasy with a reverse cam. BTW does anyone know how fast soarers go in reverse??
Simon Triantafillou
Soarer Turbo
Saturday, October 08, 2005 - 11:31 pm, by:  Simon Triantafillou (Soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Around 50km/h... same as first gear.
Avin Luther
vic
Soarer V8 uzz31
Sunday, October 09, 2005 - 12:20 am, by:  Avin Luther (Lex_luther) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
anybody tried to break a windscreen from the outside! its not that easy!
simple to do from the inside though! i once cracked one by tapping on it to get a bug to fly away
Sunday, October 09, 2005 - 06:02 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Using your stiletto heels?
Sunday, October 09, 2005 - 07:26 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Avin Luther
vic
Soarer V8 uzz31
Sunday, October 09, 2005 - 07:30 pm, by:  Avin Luther (Lex_luther) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
right fist actualy,
your mum wouldnt lend me her shoes!!!
Kris Antczak
Monday, October 10, 2005 - 01:24 pm, by:  Kris Antczak (Lexus_v8) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thats a cracker
