  SoarerCentral * Bodywork and Exterior * Found this 97 bar, had to buy it.. Previous Previous    Next Next
Paul Drane
Tuesday, October 11, 2005 - 04:57 pm, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Found this 97 bar while I was looking for something else last week.
97 bar
fog lights
bonnet seal
grille insert
foam backing pad
all the bolts
side indicators
pair of glass high beam lights
Got the lot for $465, couldn't say no.
Just got to budget for some paint work now.
The only thing missing was the Griffin.
Gary Morriss
2.5 TT
Tuesday, October 11, 2005 - 05:14 pm, by:  Gary Morriss (Gaza) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You Lucky B/stard
good find Paul
SO How much do you want for it? hehehe
Emanuel Spinola
Tuesday, October 11, 2005 - 05:42 pm, by:  Emanuel Spinola (Manny) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nice find - did they happen to have a matching 97 rear bar?
Sam Schreck
vvt-i JZZ31
Tuesday, October 11, 2005 - 05:44 pm, by:  Sam Schreck (Schreck300) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Do the BFI intake before you put it on.
Paul Drane
Tuesday, October 11, 2005 - 06:06 pm, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They bo have a rear bar, but it has got some damage, didn't pull it off the rack to get a better look at it, should go back and check it out.
Paul Drane
BFI is going to be done.
Robert Petrovski
Tuesday, October 11, 2005 - 06:23 pm, by:  Robert Petrovski (Robche) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Paul where did you find it? some wrecker in brizzy? what else did they have?
Craig Webber
Rating:
Votes: 1 (Vote!)
Tuesday, October 11, 2005 - 07:17 pm, by:  Craig Webber (Soarr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You couldn't help yourself could you.
NO NO NO NO NO OK I'LL buy it.
Now how do you hide this from the boss hmhm.
A lot of job's around the house to be done now,ha
Justin Hughes
V8 UZZ31 LTD
Tuesday, October 11, 2005 - 07:38 pm, by:  Justin Hughes (Juzza) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Paul Drane
Tuesday, October 11, 2005 - 09:17 pm, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
HA HA HA to you Craig, bit of luck finally came my way.
Robert all they've got left now is a V8 front cut with motor and trans
a TT front cut with motor and trans
a couple of doors
They are still sorting a lot of stuff out, got two sheds going, but did say they might be getting some more in soon.
That's just what I saw while I was there.
Brett Moloney
Wednesday, October 12, 2005 - 12:44 pm, by:  Brett Moloney (Lxsv8) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Paul good to meet you the other day.
If you accidentally spray paint your new front bar in dark blue let me know and i will take it off your hands for you!
Paul Drane
Wednesday, October 12, 2005 - 01:48 pm, by:  Paul Drane (Paulwd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If I accidentally paint it blue Brett, I will have to paint the rest of the car.
It was a pleasure meeting you and your wife as well, hope you can make it to Coffs Harbour in Nov. Should be a good weekend.
