  SoarerCentral * Bodywork and Exterior * Stock ride height Previous Previous    Next Next
Dave Hart
Not Australia
UZZ32
Monday, October 24, 2005 - 04:16 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does anyone know the correct stock ride height on a V8, front and back?
From ground to top of wheel arch.
There's a couple of cms diff on mine so not too sure which corners need adjusting, up or down.
John Street
V8 UZZ31 Limited
Monday, October 24, 2005 - 06:29 pm, by:  John Street (Rex2ce) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not sure what the correct height is , but my car is higher on drivers side rear by 10 mm and drivers side front by 5 mm with the car unoccupied,it levels itself when someone sits in the drivers seat
Dave Hart
Not Australia
UZZ32
Monday, October 24, 2005 - 08:38 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Looking back through the threads...
from wheel centre to wheel arch f=360mm;re340mm.
Mark Paddick
Soarer UZZ31
Monday, October 24, 2005 - 09:56 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Remember that the rear cannot be adjusted independantly, only both sides together. Front is independant.
The factory ride heights are given in detail on Planet Soarer. These are measured from the control arm bush to ground.
UZZ32 V8 Soarer #183
Monday, October 24, 2005 - 11:16 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does that also apply to an Active, Mark??
Mark Paddick
Soarer UZZ31
Monday, October 24, 2005 - 11:26 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Actives are different ride height but Pete's got all the specs here;
http://planetsoarer.com/lower/Lower.html
...And Actives may have independant rear adjustment...I'm not sure.
John Street
V8 UZZ31 Limited
Tuesday, October 25, 2005 - 09:19 am, by:  John Street (Rex2ce) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mark,
when you say that the rear can only be adjusted at the same time and not independently, could you please explain the procedure,as Steve Cheethams tutorial does not mention this
Damien Smith
Manual UZZ31
Tuesday, October 25, 2005 - 12:11 pm, by:  Damien Smith (Damien) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There's only 1 airline going to the rear airbags so whatever change you make on the rods changes both rear airbags.
Eg. if your rear left is too low you can't raise just that corner - you need to drop the front right to even it out.
Mark Paddick
Soarer UZZ31
Tuesday, October 25, 2005 - 12:23 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Exactly right
Actives may be different...never really looked.
Delan Peiris
UZZ31 V8 LTD
Tuesday, October 25, 2005 - 11:01 pm, by:  Delan Peiris (Delanx) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What is this control arm bush? what does it look like and where should i measure it from? Sorry about all the questions. My Soarer height has been adjusted using rods. I want to get it to stock height. Now I have a height controller...
