  SoarerCentral * Bodywork and Exterior * Headlight sealing Previous Previous    Next Next
Adam Underwood
Saturday, October 29, 2005 - 01:17 pm, by:  Adam Underwood (Adam_underwood) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi,
Just wondering what glue to use to seal the headlights after cleaning. Rememeber reading a post about this but cant find it now.
Thanks
Saturday, October 29, 2005 - 02:37 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mastic if you want to be able to ever undo it again.
Adam Underwood
Saturday, October 29, 2005 - 03:34 pm, by:  Adam Underwood (Adam_underwood) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks peter will start that now just did the air con filter it was really bad removed a Japanese toll collector and the ECU reset
Saturday, October 29, 2005 - 05:09 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Your air con filter removed a Japanese toll collector? Was it really bad? Did the blood short the ECU causing it to reset? Try punctuation Adam.
Saturday, October 29, 2005 - 05:50 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And please don't post duplicates in different areas.
