  SoarerCentral * Bodywork and Exterior * New HID Kit Fitted and Loving It! Previous Previous    Next Next
Open in new windowArchive through November 13, 2005Alan Chow19
Kris Blackler
V8 LTD
Sunday, November 13, 2005 - 08:39 pm, by:  Kris Blackler (Sleekcar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
when you say $400 for group buy tell me you dont mean per person....
Jeff Harper
UZZ32 Active V8
Sunday, November 13, 2005 - 11:09 pm, by:  Jeff Harper (Jeffh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bugger what they look like, do they improve night vision on your average road?
I'm getting really tired of having to get out and see if my lo beams are actually on! Serious.
Kris Blackler
V8 LTD
Sunday, November 13, 2005 - 11:14 pm, by:  Kris Blackler (Sleekcar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
im in the same boat with you jeff. maybe if i actually got the brasso out and cleaned them it might help. but better visibility is the go. i just want to know how much its gonna set my pocket back.
Alan Chow
Sunday, November 13, 2005 - 11:18 pm, by:  Alan Chow (Kfchow) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ahhh i remember those days... the days where people would flash their lights at me because i didn't know my lights were off hahaha...
yeah HIDs are great... supposidly 10x brighter but for me i reckon it gives enough visibility to drive safely:-)
Mustafa Akgul
JZZ30-GTTL
Sunday, November 13, 2005 - 11:25 pm, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jeff Harper wrote on Sunday, November 13, 2005 - 11:09 pm:
most definetly worth it.as long as you dont go higher than 6000k bulbs.
i was in the same boat as you Jeff now its so much better..
Mustafa Akgul
JZZ30-GTTL
Sunday, November 13, 2005 - 11:33 pm, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Black/Black JZZ30 VVTi
Monday, November 14, 2005 - 01:16 am, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jeff, they do put out better light on the road. I'm yet to take some pics of in-cabin, but street signs and lane markings are easier to see (much more reflective) as well as seeing emergency vehicles from further distances.
Monday, November 14, 2005 - 01:17 am, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Kris Blackler wrote on Sunday, November 13, 2005 - 08:39 pm:
Hope you realise that HID's are a full system not just bulbs.
Monday, November 14, 2005 - 09:52 am, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cheer up Kris. After all, we do not mean per light.
Monday, November 14, 2005 - 10:00 am, by:  Daniel Lee (Son_gokou) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I got my 4300k HID kit from Ians and i'm very happy with the HID kit
The HID really lights up the road and the cat eyes too!!
If you can get 10+ people interested in getting the HID Kits, i'm sure Ian will be happy to do a group buy for the club
Check out Ian's site:
http://www.jaracing.com.au/
Mustafa Akgul
JZZ30-GTTL
Monday, November 14, 2005 - 09:49 pm, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
my hid kit cost me $170 us plus delivery wasnt charged any duties.and purchased a single unit no group buy....
food for thaught.:-)
Kris Blackler
V8 LTD
Monday, November 14, 2005 - 09:56 pm, by:  Kris Blackler (Sleekcar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hmm i guess i dont fully understand the Hid kit yet. but i do want a set :-)
Mustafa Akgul
JZZ30-GTTL
Monday, November 14, 2005 - 10:01 pm, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
which part you dont understand mate? think of an ignition coil...then think of the spark that comes out of it....then when that ignites the special gas inside the bulb that is what produces the massive amount of light..
a coventional bulb has a filament just like the light globe in your average house.it works by causing resistence which makes the filament "burn" hence produces light.
both are totally different to each other. hid system also uses much less power compared to conventional lighting system..
hope this helps..
Shane McInnes
Monday, November 14, 2005 - 10:34 pm, by:  Shane McInnes (Soarin_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mustafa can you still get the HID kit you have for $170 US?
Monday, November 14, 2005 - 10:56 pm, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for clearing things up Muz.
Kris, the HID system is literally plug and play. The hardest part of the install is finding a place to mount the ballast, but all it is (connection wise) is OEM headlight connector -> HID ballast -> HID wiring harness (if it's a separate part like in mine) -> HID globe. The HID-look lights that can be easily scooped up on eBay don't do jack for the lighting... the white light emitted is actually dimmer than the OEM bulbs (which aren't too bad if you've got near new headlights) as they are tinted blue (in all cases I've seen anyway).
Mustafa Akgul
JZZ30-GTTL
Monday, November 14, 2005 - 11:43 pm, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i have emailed the guy waiting for reply..
Shane McInnes
Tuesday, November 15, 2005 - 04:28 pm, by:  Shane McInnes (Soarin_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cheers Muzzy...
Thursday, November 17, 2005 - 12:31 am, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sigh. I've been trying to contact Ian for a long long time, with no avail. Does anyone have his number, or email? I've lost his number, and my computer's motherboard fried itself.
Thursday, November 17, 2005 - 09:02 am, by:  Daniel Lee (Son_gokou) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Vinh,
Here is Ians number: 0404 546 549 and his email:
sales@jaracing.com.au
Thursday, November 17, 2005 - 03:12 pm, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I love you Daniel.
Thursday, November 17, 2005 - 05:57 pm, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mustafa Akgul
JZZ30-GTTL
Thursday, November 17, 2005 - 10:26 pm, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Vinh Bui wrote on Thursday, November 17, 2005 - 03:12 pm:
I love you Daniel.
