  SoarerCentral * Bodywork and Exterior * Will these wheels fit? Previous Previous    Next Next
Tim Zhao
Celsior!!!
Saturday, November 12, 2005 - 11:08 pm, by:  Tim Zhao (Key) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi all, The wheels are 16/7, 5 STUD235/60/16 SERIES TYRES off of a Toyota RAV-4. I wasn't sure if these will these fit on a Celsior?
Avin Luther
vic
Soarer uzz31 Limited
Saturday, November 12, 2005 - 11:46 pm, by:  Avin Luther (Lex_luther) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
you are missing one peice of information,
5 stud yes, but what spacing between the holes for the studs?
I think soarers are 5 by 114?
60 series tyres look big! what is the diameter of celsior wheels/ tyres?
Black/Black JZZ30 VVTi
Sunday, November 13, 2005 - 02:09 am, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Also the offset on them. I don't think they will fit but give it a shot anyway.
Sunday, November 13, 2005 - 10:48 am, by:  Morgan Cross (Morgan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You are after a PCD of 114.3.
You'll probably find they will fit your celsior, but the offset could be all wrong and the car will handle like a sofa bed. :-(
Tim Zhao
Celsior!!!
Sunday, November 13, 2005 - 04:37 pm, by:  Tim Zhao (Key) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The wheels one my Celsior is a 215/65/R15 , so i think the diameter should be ok.. and just not sure the offset for the Rav4 wheels, so if the offset same ,then is that mean i can put them on for no problem??
Sunday, November 13, 2005 - 06:35 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have no idea whether the offset is correct but you have a problem with diameter. If your standard wheel is 215 x 15 / 65 then a 235 x 16 / 60 increases rollout by 4.2% which is illegal, quite apart from the considerable effect on speedo and odometer accuracy and on acceleration. The limit is 3% in most jurisdictions.
If you want a 235/60 tyre then fit it to a 15" wheel or if you want a 16" wheel then use a 55 profile tyre (235 x 16 / 55). Either is only a +0.6% variation on your current rollout.
Tim Zhao
Celsior!!!
Sunday, November 13, 2005 - 06:47 pm, by:  Tim Zhao (Key) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks David!! I got it now!
