  SoarerCentral * Bodywork and Exterior * Weathershields * Archive through August 19, 2005 Previous Previous    Next Next
3.0GT
Thursday, August 18, 2005 - 03:32 pm, by:  Mike Triggs Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I know this has been mentioned earlier, but I'm trying to remove the weathershields from our '95 Soarer to put on the '97. I nearly have the passenger side one off, all that remains is double-sided tape. Presumably this can be cleaned off the door and a new lot used for the new car? The little clips have been removed.
I'm surprised Airplex in NZ don't do this item for Soarers, they make good stuff.
3.0GT
Thursday, August 18, 2005 - 06:32 pm, by:  Mike Triggs Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks, Jeff, I have already cut some with my trusty pocket knife. What can I use to clean off the old tape? I have Turps, Metho and White Spirits. Is this a special "weatherproof" grade of doublesided tape?
Ian Johnston
UZZ30 GT 4.0
Thursday, August 18, 2005 - 08:36 pm, by:  Ian Johnston Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jeff?
Thursday, August 18, 2005 - 08:45 pm, by:  Don Bagnall Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It's Aunty's new nickname
Jeff Harper
UZZ32 Active V8
Thursday, August 18, 2005 - 08:49 pm, by:  Jeff Harper Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Try either that Orange Sol stuff for grafitti or prepsol/preptone.
The removal of badges and the like is best done with dental floss, works a treat.
Signed
Neill
Thursday, August 18, 2005 - 08:57 pm, by:  Don Bagnall Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
One "l"
3.0GT
Thursday, August 18, 2005 - 09:22 pm, by:  Mike Triggs Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ahhh, thanks Jeff.. or Neill.. or Neil
Jeff Harper
UZZ32 Active V8
Thursday, August 18, 2005 - 10:16 pm, by:  Jeff Harper Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Fcuck you, I'm Neill if I wanna be Baaaagnal!
Sam Schreck
vvt-i JZZ31
Thursday, August 18, 2005 - 10:43 pm, by:  Sam Schreck Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike, I got mine off with 2 new razor blades and a crap load of wax & grease remover. A couple of little hickups but all in all it worked fine. As for the clips, grab hold with a pair of pliers and pull, Hard.
Sam Schreck
vvt-i JZZ31
Thursday, August 18, 2005 - 10:44 pm, by:  Sam Schreck Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oops, just re read and see that you already have them off. Just pay attention to the second half of my post in that case. If you want.
Friday, August 19, 2005 - 02:08 am, by:  Benny Gammelmark Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You mean the first part or DON'T pay attention to the second part or what?
UZZ32 ( V8 )
Friday, August 19, 2005 - 07:34 am, by:  Perry Morgan Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
JEEEBUS PEOPLE! Razor blades on ya paintwork! Get your hands on a good strong bit of medium sized fishing line and pull/saw through the tape with it. Can't slip then and works a treat.
3.0GT
Friday, August 19, 2005 - 09:18 am, by:  Mike Triggs Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Actually, I don't yet have them off, only the little scivets that hold them to the clips, and some of the glue on the passenger side. The fishing line's a good idea, I have heaps (as a fisherperson type)
3.0GT
Friday, August 19, 2005 - 07:30 pm, by:  Mike Triggs Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I now have them both off, pretty easy, the hardest part was getting the old tape off the doors. No solvent worked well (couldn't get hold of prepsol in the small quantity needed) even tried eucalyptus oil. The most useful tool was a plastic knife, especially after it broke!
