  SoarerCentral * Bodywork and Exterior * Getting new paint job, what to ask for? Previous Previous    Next Next
David Watts
(include TT or V8)-- neither! inline 6
Monday, August 22, 2005 - 12:42 am, by:  David Watts Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey guys imported a 1994 soarer sc300 (3.0 GT) and its dark metallic green.. anyways it was a bit of a nightmare and it turned up with some scratches so i got the option of fixing up the panels with the scratches for roughly $1k, or i can go the full respray for the $2-$3k option, so ive decided to go with that...
anyway what i'm after is a full black respray, but the metalic black type colour, does anyone know the colour code for a really bright/metallic like black, or the proper name for it?? also i want to get the car debage - will it cost much extra for the holes to be covered/painted?
thanks in advance, dave.
thanks for your help
Monday, August 22, 2005 - 09:34 am, by:  Daniel Lee Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
David,
Here have all the colour codes for the Soarer :-)
http://www.toyotaimportsforum.co.uk/soarer/z30soarer_colours.htm
David Watts
Monday, August 22, 2005 - 10:54 am, by:  David Watts Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Daniel Lee, so are you saying the orginal black for the soarer fits the description for what im after? a bright, metallic like black? Or is it just black is black, they are all the same.
Monday, August 22, 2005 - 11:33 am, by:  Don Bagnall Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Code 202 is plain non-metalic Black.
Monday, August 22, 2005 - 12:07 pm, by:  Benny Gammelmark Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Black ain't just black. A paint shop should be able to help you.
The alternative is to go to Auto One or Autobahn. They should have full colour descriptions available.
