  SoarerCentral * General Soarer Chat * What a long day Previous Previous    Next Next
Charlie Hooper
V8 Limited Soarer
Sunday, September 17, 2006 - 11:13 pm, by:  Charlie Hooper (Charlie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well, at around 2pm after reading a few things here I figured I'd clean my air con filter. I pulled it out and it was caked with black stuff, hair, sticks and other bits and peices.
After I pulled that out I figured "hey, why not fix up the DVD player instead of having those cables hanging out the front of the glovebox" so I started pulling more apart. I cut the hole inside the glovebox so the DVD player sat back in further and ran the cables so they where all hidden like.
While I was there I figured "hey, why not try and get rid of that annoying engine whir noise that happens when you use the DVD player?"
That's when I struck trouble haha. I spent hours googleing and searching forums figureing there *must* be an easy fix. I ended up trying about 5 different ways others had reported they got it working without engine noise and it hit about 10pm so it was too late to try to buy a earth loop isolator. I cracked it and gave up, put everything back together and am now drinking beer to try and get over the frustration haha
Although, I do feel good (as I always do when I find a howto here and finish it and see the results) as now I can keep my cigg lighter panel down instead of having the cable running from the glovebox to it. So cheers soarer central.
That's my story, it's not a great one, I may or may not write a book about it one day... hahah
Ben Daniel
Sunday, September 17, 2006 - 11:19 pm, by:  Ben Daniel (Lexustt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'll take 3 copies ! Signed too :P
Iain Morrison
2JZ-GE JZZ31
Reg: 05-2006
Sunday, September 17, 2006 - 11:59 pm, by:  Iain Morrison (Iain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Charlie Hooper wrote on Sunday, September 17, 2006 - 11:13 pm:
I'll wait for the movie to hit the cinemas...
Charlie Hooper
V8 Limited Soarer
Monday, September 18, 2006 - 12:27 am, by:  Charlie Hooper (Charlie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hahah... I don't think I could sign them as my finger tips are all cut up from playing with wires... will a big X do? :-)
Also, I'm going to be building an in-car PC soon, will take pictures all the way through, where's the best place to send a how-to?
I'll start when I can find a decently priced DC-DC ATX PSU
Monday, September 18, 2006 - 12:32 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Charlie, post any How-To's into the Articles of Interest area, then I can move it :-)
