  SoarerCentral * General Soarer Chat * Heart broken (smash) Previous Previous    Next Next
Kevin la Terra
soarer GTTL
Tuesday, October 17, 2006 - 05:47 pm, by:  Kevin la Terra (Trdpsi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yesterday around 5:30 pm i was comming out of the petrol station and was travaling home, when a little exel didnt give way while comming out of the train station car park.
She just drove out like I wasnt there, luckly she didnt stop or else I would have hit her strait on the drivers door.
I ended up collecting the rear quater panel on the exel, Therefor I hit her on my front drivers side... Absolutly gutterd....
So it was totaly her fult and she knows that, she is fully insured wich is good, and I have a few witnesess too....
So sh!t happends I guess luckly no one was injerd.
Steven Nanevski
JZZ30 TD04 Twin Turbo (coming soon!)
Tuesday, October 17, 2006 - 06:02 pm, by:  Steven Nanevski (Imprestik) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Damn, tough break man...
But she will be up and ready again in no time...
Tuesday, October 17, 2006 - 06:27 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bummer Kevin
From the pic it looks like the guard & headlight took most of the impact........the front bar looks like it absorbed a lot of it.
Bill Bogiatzis
Tuesday, October 17, 2006 - 09:28 pm, by:  Bill Bogiatzis (Boggie23) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There doesnt seem to be structural damage to the chassi but could it be a write off. There is a good 4 grand damage at least done to it and then painting it.
Do you want it repaired?
It is a pretty straight forward fix. Hope all the best for you.
Nathan Evans
1JZZ30 TT
Tuesday, October 17, 2006 - 09:43 pm, by:  Nathan Evans (Soarer7) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
definently just a wax on wax off job, must have sucked driving it home like that (assuming thats what you did)
Ben Socratous
Iv'e started to put my interior back together!!!
Tuesday, October 17, 2006 - 10:21 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bill Bogiatzis wrote on Tuesday, October 17, 2006 - 09:28 pm:
Please explain...
Most insurance companies will repair the car if the damage comes to less than 75-80% of the agreed value, you usually don't get to chose whether they repair or scrap it, or at least that has been the case in my claim, and that of everyone else I know!
Daniel Trivuncevic
Tuesday, October 17, 2006 - 10:28 pm, by:  Daniel Trivuncevic (Madm0nk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
$4k?...dude, i had my rear quarter choppped off, re-welded on, with the wheel arch basically being rebuilt, the car resprayed to a totally new colour, including inside the door sills and all that and it only cost me $3000.. no way is there $4000 of damage there unless your an over-pricing son of a dog..
94 UZZ31 (V8) / 96 JZZ30 (TT)
Tuesday, October 17, 2006 - 10:42 pm, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
New fender, new bonnet, new front bar. All which can be sourced second hand. These parts plus paint shouldn't cost $4000. And if they do, change smash repairer :-)
Bad luck on that accident though. If that was me, I'd probably be in jail for physically abusing the other driver!
Sean Tusler
Tuesday, October 17, 2006 - 11:54 pm, by:  Sean Tusler (Viperlover55) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That sucks Kevin!! i have had sooo many close calls, there are some many people who just dont look, its a shame that drivers are not better educated, i hope you get you car fixed without problem. :-)
Wednesday, October 18, 2006 - 12:36 am, by:  Benny Gammelmark (Oldfield) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Vinh Bui wrote on Tuesday, October 17, 2006 - 10:42 pm:
Since it's not his fault I would expect everything to be fixed properly (new parts). That will cost a lot more than $4K.
It doesn't look like a std. Soarer colour but I could be wrong. If it isn't then paint matching comes into it which means you have to use a top of the line paint shop. They ain't cheap.
I would say a proper job with new parts would cost around $6K.
Wednesday, October 18, 2006 - 01:15 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Her insurance company is paying for it, so who cares how much it costs?
Scott Ferguson
Alberta
Soarer GTT-L
Reg: 07-2006
Wednesday, October 18, 2006 - 01:29 am, by:  Scott Ferguson (Scott_ferguson) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well if it's too much they'll write it off and no one gets a good deal out of a write off.
Good luck man
Adam Lonergan
UZZ32
Wednesday, October 18, 2006 - 06:46 am, by:  Adam Lonergan (Alchemistal) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Swap the rims to stock in case it's a write off :-)
Wednesday, October 18, 2006 - 10:35 am, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah Benny, I know those parts brand new would cost well ove $4000. I was just saying that IF her insurance company somehow gets out of it, he'll at least know he won't have to spend 4K just to fix his car.
But hopefully she'll pay up.
Wednesday, October 18, 2006 - 12:18 pm, by:  Benny Gammelmark (Oldfield) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maybe it would be a good thing to get the car written off (if you can buy the wreck).
You can THEN go get second hand parts.
Kevin la Terra
soarer GTTL
Wednesday, October 18, 2006 - 01:32 pm, by:  Kevin la Terra (Trdpsi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cheers guys, the car is at the panel beaters already and should be fixed by the end of next week.
Benny, the car is stock color (burgandy 3k3)
I dont think they will be using new parts, but to be honest i dont really care. As long as the job is good and back to normal I will be more than happy.
Wednesday, October 18, 2006 - 05:18 pm, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Kevin, don't you think you're rushing into it? Or are you familiar with the panel beaters you are using?
I'd recommend you do some research and some general asking around before you let anyone touch your car.
Are you paying for it Kevin or is her insurance company paying for it?
Wednesday, October 18, 2006 - 06:18 pm, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Fsking insurance companies. I would have thought a "write off" would indicate the car could not be returned to road worthy status.
Wednesday, October 18, 2006 - 06:35 pm, by:  Daniel Czechowski (Dan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
A write off as in financial write off Callum, no point paying X amount of dollars for something that is not worth the repair.
Kevin la Terra
soarer GTTL
Wednesday, October 18, 2006 - 08:00 pm, by:  Kevin la Terra (Trdpsi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Vinh
her insurance company is paying to get fixed.
I cant belive how quick the ball is rolling useally it takes a few weeks if not months to get going.
The pannel beaters is a local one who is recommended by her insurance company (RACV)
wich is a good pannel beater cos i know alot of people who has used them, so that was a bonus.
guys its only the bonnet, gard , bumper and headlight, theres no way it can even come close to a write off. Id need to do about 6 to 8 grands woth of damage before they consider that.
But if it was id be taking of all the goodies before giving the car to them.
Wednesday, October 18, 2006 - 09:22 pm, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Kevin, well at least you know the work they're capable of.
Yeah, I'm surprised they already processed your claim and recommended you a panel beater 48 hours after the accident. Let's hope the panel beaters pay more attention to fixing your car than the insurance money.
Kevin la Terra
soarer GTTL
Wednesday, October 18, 2006 - 09:29 pm, by:  Kevin la Terra (Trdpsi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So do I mate, hey if the jobs not done right ill be telling them dont u worrie!!!
Im gonna go talk to the bloke tomorro so ill tell him "no rush job" or eles i wont accept it, but I know his work is A1 anyway.
Bill Bogiatzis
Wednesday, October 18, 2006 - 10:07 pm, by:  Bill Bogiatzis (Boggie23) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oh no that was a 97 model front bar with front lip
Wednesday, October 18, 2006 - 10:14 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Being nice to him may be more useful than offering him a challenge.
UZZ 32 V8 Soarer #138
Wednesday, October 18, 2006 - 10:31 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bummer, Kev, That was a real nice machine.
Hopefully soon it will be all good again.
UZZ32 ( V8 )
Thursday, October 19, 2006 - 06:51 am, by:  Perry Morgan (Uzz32) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bill Bogiatzis wrote on Wednesday, October 18, 2006 - 10:07 pm:
Insurance company may get a bit suss tho Bill when they discover there is no lip for the 97 bar haha.
Kevin la Terra
soarer GTTL
Thursday, October 19, 2006 - 02:58 pm, by:  Kevin la Terra (Trdpsi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
cheers guys
even though i dont drive the car much, just during on the week ends, it just sucks not having it in the shed.....lol
Charmaine Lim
Toyota Soarer v8
Reg: 08-2007
Monday, November 19, 2007 - 08:43 am, by:  Charmaine Lim (Charmie87) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've got a question/rant regarding this kind of stuff...
If you don't know already i was in an accident, i was following my boyfriends car and we were going straight through a T intersection, a lady gave way to his little pulsar but failed to see me. I swerved out of the way (lucky no one was coming from the other direction!) and she hit my passenger side rear wheel and the bumper.
It's been towed by Aami to their workshop/s.... this happened coming on to a month ago now. My car has just been sitting in the hot sun for almost a month now. I call Aami atleast twice a week because no matter how much they say they'll call me they never do. And they never have any information for me, they said because the car is imported they are having trouble getting quotes.
I was devastated at first, now i am just P****d off.... a whole months seems a long time to just have my car sitting there at square one. I don't even know if it is a write off or not yet.
Does this seem right to anyone? Any similar experiences? I think by the end of this week i am going to go into Aami and tell them i need to know what is going on because i just feel like they're doing a big fat nothing :-(
I work 2 jobs for this car, and it sucks paying 90% of my income to a car that i don't even have. I am fortunate enough to have my grandparents Rover to use while they are away, but they will be back in a matter of days and i will be carless. Which isn't going to be easy when i work full time then have to go to my 2nd job and finish by midnight. It is very impossible to work with bus' when i work stupid hours.
I wish i wasn't craving a kebab so badly that day...
Soarer GT-T (sold :-( ) & IS300 Sports Luxury
Monday, November 19, 2007 - 10:52 am, by:  Daniel Czechowski (Dan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If it's taking them a month to do something, try to perhaps speak to their customer relations dept and lodge a complaint. If that fails, call the insurance ombudsman, a month with no progress is way too long. They should not be having any trouble getting quotes, parts are relatively easy to get hold off nowadays, and any panel beater will be able to fix it. Sounds like a bullshit excuse to me.
Suresh De Mel
Monday, November 19, 2007 - 12:29 pm, by:  Suresh De Mel (Resh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Kevin could you have taken it to your choice of repairer? I know from personal experience that GIO do.
Could have been more beneficial for you
Braden Murdoch
Cressida 1JZ TT
Monday, November 19, 2007 - 03:13 pm, by:  Braden Murdoch (Ribfeast) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That sucks man :-( They should be providing you with a vehicle since yours is off the road, and you shouldn't have to be out of pocket at all! You weren't at fault!
Matthew Crawford
Tuesday, November 20, 2007 - 12:29 pm, by:  Matthew Crawford (Doink) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does woeful grammar and spelling count as SMS speak?
I find this thread incredibly hard to read.
Charmaine Lim
Toyota Soarer v8
Reg: 08-2007
Wednesday, November 21, 2007 - 10:39 am, by:  Charmaine Lim (Charmie87) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My car is a write off :-(
Lexus Roller Coaster
Wednesday, November 21, 2007 - 11:21 am, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Grab what you can Charmaine before insurance claims it !
