  SoarerCentral * General Soarer Chat * Lighten up Previous Previous    Next Next
Mike Bradberry
Wednesday, November 22, 2006 - 02:51 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think I'll take out the spare wheel and remove the back seat for the dyno run on Saturday.
Rehan Bandara
Reg: 10-2006
Wednesday, November 22, 2006 - 03:09 pm, by:  Rehan Bandara (Parsec) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
how does less weight improve your dyno reading?
Mike Bradberry
Wednesday, November 22, 2006 - 03:19 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Antony Borlase
UZZ31 (V8 Limited)
Wednesday, November 22, 2006 - 04:09 pm, by:  Antony Borlase (Borlase) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maybe the shock loadings, from the car bouncing up and down on the rollers, imparts more potential?
Sort of like a perpetual motion machine only smelly?
Wednesday, November 22, 2006 - 04:14 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Generally they will Add more weight if it has traction problems... But unless your pushing over 400rwhp.. that shouldnt be an issue.
Freeman Tang
JZZ30 GT-TL
Wednesday, November 22, 2006 - 05:41 pm, by:  Freeman Tang (Cobra_man) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike is just being sarcastic.
Lew Radbourn
jzz30 ute / uzz30/ 2 X uzz31
Thursday, November 23, 2006 - 07:12 am, by:  Lew Radbourn (Marlew) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tim Appleton
Thursday, November 23, 2006 - 08:24 am, by:  Tim Appleton (Timbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you can get a set of smaller diameter, lighter wheels then you'll get a better figure. There's less rotational inertia to overcome, but will only really work for shoot-out mode where the rpm varies quickly.
Nathan Evans
1JZZ30 TT
Thursday, November 23, 2006 - 10:41 pm, by:  Nathan Evans (Soarer7) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeh what Tim said!
Justin Camilleri
Had a 85 MZ10, 92 TT, Now 91 TT
Thursday, November 23, 2006 - 11:21 pm, by:  Justin Camilleri (Just) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Space saver?
