  SoarerCentral * General Soarer Chat * Want To Buy a GPS for my GT-L EMV Soarer - But Which One? Previous Previous    Next Next
Michael Howatt
4.0 GT-L - V8 - UZZ31
Reg: 12-2005
Thursday, December 14, 2006 - 11:42 pm, by:  Michael Howatt (Howatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Everyone, I have decided to obtain/buy a GPS for my UZZ31 GT-L. I want a GPS system that is integrated into/with my EMV.
I know that it will need to be controlled remotely via Infra Red however, I am in a mess.
Which system out their in the market place is the best? eg.VDO?? and where / who would be the best person to install it locally (North/West Suburbs in Melbourne).
Ray Crawford
GT Limited V8 UZZ31
Friday, December 15, 2006 - 08:38 am, by:  Ray Crawford (Ray) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I bought a second hand Philips Carin GPS system out of a Sonata and had it fitted to my Soarer. It works great via the EMV. The GPS unit is in the boot and the control unit hidden in the centre console box.
Adam Sanders
Friday, December 15, 2006 - 10:11 am, by:  Adam Sanders (Abz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have a VDO Dayton ms5000/6000 in my Ls400.
I would pick one of these up I have seen them go for $600 on ebay new.
This was a $5000 new option on my car in 1998
V8 Ltd manual
Friday, December 15, 2006 - 11:09 am, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mine is Blaupunkt and works well. In fact, the process of entering addresses is superior to my factory unit in the IS300. Getting this or one of the others second hand will be a lot cheaper. Mine has the unit under the passenger seat (attached to its underside) which is fine if you never push the seat all the way forward. Antenna is concealed under carpet and IR remote receiver replaces a blank switch plate under the dash to the left of the steering wheel. It has a separate speaker under the dash rather than that being through the stock speakers. Control is via a small remote with only seven buttons.
Will Adams
Soarer GT-TL
Friday, December 15, 2006 - 03:29 pm, by:  Will Adams (Draco) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ray Crawford wrote on Friday, December 15, 2006 - 08:38 am:
Ray I assume that you aren't using the screen and the input is just through an AV input? How much did it set you back? I have my display unit in my TT which has a connection for a GPS unit. I have not been able to find any anywhere to connect up to this.
Michael Howatt
Reg: 12-2005
Tuesday, December 19, 2006 - 09:49 am, by:  Michael Howatt (Howatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bump
Ray Crawford
GT Limited V8 UZZ31
Tuesday, December 19, 2006 - 10:25 pm, by:  Ray Crawford (Ray) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I only paid $250 for the system from a Hyundai wrecker. Nam installed the unit to work through the EMV screen. Nam wired the unit in and I used an underdash switch (from the rear parking pole) to switch the system over.
Nam fitting GPS
