  SoarerCentral * General Soarer Chat * Wheels to suit soarer? Previous Previous    Next Next
Noel Lae
W.A
Reg: 09-2006
Monday, January 08, 2007 - 07:53 pm, by:  Noel Lae (Noela) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
my car is on blocks at the moment waiting for my new wheels.. just wondering if any 5 stud wheel will fit without any problems? car is not to be driven but towed.
Monday, January 08, 2007 - 08:53 pm, by:  James Johnson (Jamesy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
same pattern as ford falcons so you can get anything that fits them 5x114.3!! just make sure you have the right offset. stock is +50 depending on how wide you go can have down to +40 or so
Shaun Stephenson
Jzz30 TT & ST162
Tuesday, January 09, 2007 - 10:09 am, by:  Shaun Stephenson (Neonasty) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My wheels were designed for Falcons. Luckily that means there are crap load of wheels that fill fit. Some dished ones too!
Benjamin Burgess
Toyota Soarer GT-TL
Tuesday, January 09, 2007 - 10:30 am, by:  Benjamin Burgess (Jampac) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Still have the problem of the wheel hub mount being too big. You usually need to get a insert made up to suit toyotas. Bad idea if you go drag racing with non toyota rims without the insert, can shear your wheel studs.
Bog Standard Active and a pos factory Manual XF Falcon.
Tuesday, January 09, 2007 - 11:05 am, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
For towing, don't worry about offset or anything.
Go on ebay or to a wreckers and get the cheapest wheels that will fit toyota 5 stud, nissan 5 stud or ford 5 stud and it will get you where you need to go.
Be aware that towing can destroy your auto. (unless it's on a trailer)
Sean Tusler
Tuesday, January 09, 2007 - 04:30 pm, by:  Sean Tusler (Viperlover55) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dont buy mine, everyone thinks they are ugly. (refer to profile picture)
Aaron Mead
Tuesday, January 09, 2007 - 08:10 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They look allright. Aren't they just polished stockers?
Everything mentioned above is correct. The inserts used to match your hub spigot to the wheel centre bore hole is called a SPIGOT RING. They make sure the studs are only clamping the wheel to the hub, not taking the load of the car!!
You can go pretty big on a soarer, I've gone 18x9 and 18x10, Rob Hayden has 11" wide rears on his UZZ (think they were 17"), and Im sure theres others with serious PHATS.
Noel Lae
W.A
Reg: 09-2006
Tuesday, January 09, 2007 - 09:24 pm, by:  Noel Lae (Noela) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks everyone.. wreckers were most unhelpful.. I've found some rims in the local trading post for $40 I'll just scrap some tyres together.
Sean - your rims look fine to me also!
