  SoarerCentral * General Soarer Chat * What do you recon? Previous Previous    Next Next
Alen Sadikovic
Soarer GTT
Reg: 10-2006
Sunday, February 04, 2007 - 11:44 am, by:  Alen Sadikovic (Alen87) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
good or What?????????????
Ben Socratous
I am the fibreglass/kevlar/carbonfibre king!
Sunday, February 04, 2007 - 03:29 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That would be dependant on what mods you have done
Sunday, February 04, 2007 - 07:13 pm, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What are doing a recon on ?
the 'upgarded' turbos must have helped
i dare say the supra 'barkes' help when pulling this beast up ?
Alen Sadikovic
Soarer GTT
Reg: 10-2006
Monday, February 05, 2007 - 12:39 am, by:  Alen Sadikovic (Alen87) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ben Socratous wrote on Sunday, February 04, 2007 - 03:29 pm:
don't know what turbos they are, the coils just has been upgraded but don't know to what stage, and its got just a front mount and i am running it under 18psi. i am just happy i pulled that much, after the leaks i had on it i was expecting only 210kw, the guy even said i didn't push it because he didn't know how much the turbos could handle.
James Harris wrote on Sunday, February 04, 2007 - 07:13 pm:
ohh yeh the brakes help alot, saved my life a few times, although they need to be machined and have their pistons looked at because they making squeaking nosies
" 238.7rwkw + 2JZ cams = ? "
Monday, February 05, 2007 - 10:21 am, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Very nice
Some mild cams and you're set.
Aaron Mead
Monday, February 05, 2007 - 10:26 am, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What say we ease up on those whose native tongue differs, or are less capable of mastering the local lingo ?
Not a bad curve at all, haltech interceptor eh ?Nice work!
Alen Sadikovic
Soarer GTT
Reg: 10-2006
Monday, February 05, 2007 - 10:41 am, by:  Alen Sadikovic (Alen87) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cihan Aday wrote on Monday, February 05, 2007 - 10:21 am:
cams eh? haven't thought about that yet, i was told to look into a new fuel pump for now and play around with the fuel ratio, although it has quiet a good mixture and healthy run.
i want to push it up to 250-270kw, but not sure what els to do
Monday, February 05, 2007 - 03:51 pm, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Aaron Mead wrote on Monday, February 05, 2007 - 10:26 am:
Yeh i agree.... i felt bad today i was going to edit it but its been too long.
Sorry for taking the p1ss allen , but as they say - 'Australia is a Nation of P1ss Takers..'
Aaron Mead
Monday, February 05, 2007 - 07:14 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oooh, I aint judging nobody, I am the worst! But indeed, we are the nation of pisstaking!
Monday, February 05, 2007 - 08:52 pm, by:  Maurice Diggler (Mau_rice) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Alen Sadikovic wrote on Monday, February 05, 2007 - 10:41 am:
Do you still have the stock 380cc yellow injectors? If so, I'd upgrade them before you bother with the fuel pump, a stock JZZ30 fuel pump in good health has a a bit left in it at 230rwkw.
Also, what are you using to control boost? It doesn't seem to be very stable? Cheers.
Alen Sadikovic
Soarer GTT
Reg: 10-2006
Tuesday, February 06, 2007 - 12:47 pm, by:  Alen Sadikovic (Alen87) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maurice Diggler wrote on Monday, February 05, 2007 - 08:52 pm:
if you are referring to a boost control, i don't have one ahaha, to scared to buy one, will get tempted to boost it up and stuff the turbos. but your right i don't have constant boost, i can feel it when i drive the car. sometimes it kicks in hard sometimes it dont
Tuesday, February 06, 2007 - 07:32 pm, by:  Maurice Diggler (Mau_rice) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Alen Sadikovic wrote on Tuesday, February 06, 2007 - 12:47 pm:
If you don't, how are you running 18psi?
Tuesday, February 06, 2007 - 07:48 pm, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
maybe he has a very free flowing exhaust... i.e no cats, no middle muffler... good dumps etc.
I dont have a boost controller and im running 1.09 BAR which is almost 16psi...
Alen Sadikovic
Soarer GTT
Reg: 10-2006
Tuesday, February 06, 2007 - 10:10 pm, by:  Alen Sadikovic (Alen87) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maurice Diggler wrote on Tuesday, February 06, 2007 - 07:32 pm:
i have no idea but you think a boost control will help ma inconsistent boost???
but i do have 2.5"inch exhaust all the way, and i am pretty sure i have cats, my friend said he sore them last time we looked under the car, thats that box yeh?
94 UZZ31 (V8) / 96 JZZ30 (TT)
Wednesday, February 07, 2007 - 01:08 pm, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yep, a good (READ: good) boost controller should be able to hold the boost level. You can never go below your natural boost anyway. You can even make boost come on earlier if you wanted.
