  SoarerCentral * General Soarer Chat * Groaning steering. Previous Previous    Next Next
Black V8
Sunday, February 25, 2007 - 10:39 pm, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
OK just over the past few days my steering has begun to really groan. It does it when im trying to turn into car parks and around corners in the street. It feels like i have a flat tyre or the power steering pump is on its way out ?
Recently i pumped all tyres up to 37PSI and ironically its only happened since doing that. Yet it doesnt make any sense.
Today i checked the Power Steering fluid level and it seemed ok but Im not sure if it was hi or low.
Any ideas, as its getting worse every day.
Sunday, February 25, 2007 - 11:19 pm, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm only brainstorming here... could a bearing that is on its way out be the cause?
Monday, February 26, 2007 - 03:37 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Groaning is usually from air in the P/S system, though that isn't consistent with your level being OK.
I am sure you will get more correct answers during the day.
Monday, February 26, 2007 - 06:43 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'd say top the power steering fluid right up to the top to start off with. Mine was groaning and shuddering about 6 months ago - noticed the level was a bit low, but didn't seem too bad - but when I topped it up, all the problems vanished.
Black V8
Monday, February 26, 2007 - 10:31 am, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cool, cheers Matt, thats the first logical step to take. I'll try to get some fluid from SuperCheap today. Thanks Peter for the advice too.
Is there any special fluid to get or will any generic fluid do?
Brian Timms
TT Soarer Goodness.
Reg: 12-2006
Monday, February 26, 2007 - 12:57 pm, by:  Brian Timms (Turbo_brian) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
check the level of the fluid, mine was doing that when I first bought the car, and I found 2 pin-holes in one of the high pressure lines.
The growning was from the fluid getting low, and it getting air in the line, the pin-holes cost me $120 at Pirtek to repair, but I did have to remove the part myself.
B.
Monday, February 26, 2007 - 01:47 pm, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Think I just got some from the local Caltex...
Darryn Dewar
Gisborne
UZZ30 Soarer
Monday, February 26, 2007 - 04:09 pm, by:  Darryn Dewar (Mrphreak) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Adam Peterson wrote on Monday, February 26, 2007 - 10:31 am:
Should tell you on the lid what to put into it
Black V8
Tuesday, February 27, 2007 - 10:44 am, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
OK I think ive fixed the problem :-)
I got some MTF fluid from SuperCheap last nite and topped up my reservoir tank. Everything seems fine now.
Cheers for the help guys
Nathan Stringer
UZZ31 V8
Reg: 01-2006
Tuesday, February 27, 2007 - 11:25 am, by:  Nathan Stringer (Stringer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've just flushed mine, didn't make much difference though, think I'm up for a rebuilt pump. Noise is the same, a whirring when the vehicle is at idle though.
I used Dextron III.
Tuesday, February 27, 2007 - 12:22 pm, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You sure its not just a worn bearing?
Nathan Stringer
UZZ31 V8
Reg: 01-2006
Wednesday, February 28, 2007 - 03:08 pm, by:  Nathan Stringer (Stringer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Are you talking about mine Matt?
(Thread hijack)
It sounds like a bearing, but I'll have to take to pump off to replace the bearing, might as well put a kit in it while it is out.
It's covered in one of the tutorials, just got to get around to doing it.
