  SoarerCentral * General Soarer Chat * Brake this Dimensions Previous Previous    Next Next
Ben Daniel
Monday, March 12, 2007 - 06:16 pm, by:  Ben Daniel (Lexustt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey there, tried doing a search but came up empty handed. I just wanna know what the brake disc dimensions are front and rear for a 95 JZZ30.
Thanks !
Monday, March 12, 2007 - 06:35 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ben, have a look in "Soarer Specifications and Useful Information".
They are also called rotors.
V8 Ltd manual
Monday, March 12, 2007 - 06:45 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I believe they are 296mm front and 307mm rear, 32mm and 16mm thick respectively. You can take 2mm of wear on the front and 1mm on the rear.
V8 Ltd manual
Monday, March 12, 2007 - 06:48 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
A well-founded belief, it seems
Ben Daniel
Monday, March 12, 2007 - 08:12 pm, by:  Ben Daniel (Lexustt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Lol... I just saw the title saying "This" instead of "Discs" god im an idiot :-)
Ben Daniel
Monday, March 12, 2007 - 08:30 pm, by:  Ben Daniel (Lexustt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Peter, I actully didn't even think to look there...
Are you sure they are all the same size tho ? I thought from 94 onwards toyota upgraded a lot of things and 1 of them was the brakes.
Soarer VVTi
Monday, March 12, 2007 - 11:32 pm, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Brake rotor/disc (pick your poison) are the same size throughout all JZZ30's.
Jeff Wilkins
JZZ30 GT-TL
Monday, March 12, 2007 - 11:42 pm, by:  Jeff Wilkins (Calin) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Supras got upgraded in '95 Ben, perhaps your thinking of them...
Ben Daniel
Monday, March 12, 2007 - 11:48 pm, by:  Ben Daniel (Lexustt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Possibly.
Jeff, I searched every where to find a local supplier who does the JIC Magic kit and 90% of them hadn't even heard of it :-(
Jeff Wilkins
JZZ30 GT-TL
Tuesday, March 13, 2007 - 12:00 am, by:  Jeff Wilkins (Calin) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mine was on when she got here from Japan.
You could try
http://www.sinex.com.au/index.php?cPath=231_165
No idea what they're like though.
