  SoarerCentral * General Soarer Chat * Need To Get My Bonnet Open. Previous Previous    Next Next
Brad Parker
Soarer TT and a Lexus V8
Wednesday, March 14, 2007 - 08:20 pm, by:  Brad Parker (Bunit) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hello. I have a very nice 91 TT that is lowered on Tein adjustable coil overs. Unfortunately after all the years of the front right tyre scrubbing on the guard, it has worn through, cutting some of the wiring and the bonnet release cable. The bonnet release cable has totally pulled out from the mechanism at the front of the bonnet. Any tips on how to release the mechanism? Thanks.
Roger Costello
UZZ31 V8 Limited, UZZ32 no 867
Wednesday, March 14, 2007 - 09:12 pm, by:  Roger Costello (Roger) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
A sonic screwdriver would be handy. I believe setting number 14723 is release Soarer TT Bonnet.
Brad Parker
Wednesday, March 14, 2007 - 10:48 pm, by:  Brad Parker (Bunit) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes sonic screw driver, or perhaps an angle grinder. Pity Toyota uses such a good mechanism, not like the old Holden or Fords, now they were nice and easy to get open.
Nayr Civoknar
Reg: 01-2007
Wednesday, March 14, 2007 - 10:49 pm, by:  Nayr Civoknar (Ryanonejay) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sonic screwdriver?
Joseph D'Agostino
Reg: 11-2006
Wednesday, March 14, 2007 - 10:55 pm, by:  Joseph D'Agostino (Mia) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nayr Civoknar wrote on Wednesday, March 14, 2007 - 10:49 pm:
sonic screwdriver?
Dr Who owns one
Joe Radisic
2JZ GTE SingleTurbo
Reg: 10-2006
Wednesday, March 14, 2007 - 11:03 pm, by:  Joe Radisic (Joe) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
can you strip some of the outer cable to get a hold of the inner and pull on it?
Joel Moore
91 Soarer TT
Reg: 10-2006
Thursday, March 15, 2007 - 10:59 am, by:  Joel Moore (Ttsoai2ei2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
take the plastic shielding on the sides off, grab the wire with pliers and pull while a friend with a cloth and a flat head tries gently to lift it up
Bugatti Veyron
Thursday, March 15, 2007 - 11:14 am, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Do you have to say abra-ca-dabra when using this 'sonic screwdriver' ?
Craig Webber
Thursday, March 15, 2007 - 12:39 pm, by:  Craig Webber (Soarr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Here you go, got it from Dr Who.
