  SoarerCentral * General Soarer Chat * I just got a Lexus soarer se400 but how do i work th cd player/stacker Previous Previous    Next Next
James Doughton
SC400 Soarer limited v8
Wednesday, March 14, 2007 - 10:59 pm, by:  James Doughton (Jiimy_d) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
}Hi just need help on how to work the cd stacker. How do i turn it on.... Any help plz. The cds go in the stacker ok, but what do i do then.....??????
James Doughton
Thursday, March 15, 2007 - 07:47 am, by:  James Doughton (Jiimy_d) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
plz someone help. Is this a stupid question?
Luke Nieuwhof
Thursday, March 15, 2007 - 08:03 am, by:  Luke Nieuwhof (Luke_nieuwhof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
*Waits for arrival of Peter "Don't Use Text Speak Or I'll Cut Your Balls Off" Nitschke* :-)
Tim Appleton
Thursday, March 15, 2007 - 08:42 am, by:  Tim Appleton (Timbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi James,
It should be just a matter of placing the cartridge in the stacker and closing the top sliding door. The stacker should then go through and check the location of the discs in the cartridge by trying to load each one. This could take some time. Don't think the car needs to be on or anything, although it may stay active for a period after the car is turned off. The eject button should be lit up.
Check that the little tab on the underside of the door hasn't broken off. It presses up against a little microswitch near the eject button. The tab on mine had broken off, and the eject button didn't work, so I pulled it apart and installed my own remote switches.
94 UZZ31 (V8) / 96 JZZ30 (TT) / 97 JZA80 (TT)
Thursday, March 15, 2007 - 09:35 am, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If I remember correctly, isn't there some sort of arrow on the stacker and cartridge which is meant to help you insert the cartridge correctly?
Thursday, March 15, 2007 - 03:21 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
James, if you avoid the use of SMS-speak (eg "plz") you will find that you get a better response and the added advantage of your posts/account not being deleted.
212Kw @ 8psi MANUAL Super Charged UZZ31 :-)
Thursday, March 15, 2007 - 06:59 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Luke Nieuwhof wrote on Thursday, March 15, 2007 - 08:03 am:
HAHAHAHAHHAHAHAHAHHAHAHAHAHHAHAHAHAHAHHAHAHAHAHAHHAHAHAHAHAHAHHAHAHA}
