  SoarerCentral * General Soarer Chat * NEW RECORD for STOCK TURBOS! * Archive through April 07, 2007 Previous Previous    Next Next
Aka Abedin
91 G-TT, 93 GTL 31
Friday, April 06, 2007 - 04:14 pm, by:  Aka Abedin (Soarer_91tt) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just got news Daniel Clarke has broken the stock turbo record.
Ran 12.47 from memory with 1.7 as his 60 footer.
its only 4:42 now and the the drags finishes at 10pm. Lets hope he can beat that time by the end of tonight.
Shane McInnes
JZZ30 GT-TL Manual
Friday, April 06, 2007 - 05:15 pm, by:  Shane McInnes (Soarin_tt) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
WOW Well done Daniel.
Thats freaking awesome, I thought you would be lucky to get 12.5
But 12.47 is just crazy.
Congrats mate.
Friday, April 06, 2007 - 06:22 pm, by:  Daniel Clarke (Dieseltrain) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
YEah timeslip to come shortly.
Ran 12.47 @ 109.2mph with a 1.72 60 footer!
I Still cant beleive i broke the record:-)
Thanks SHane and AKa.
Joel Moore
91 Soarer TT
Reg: 10-2006
Friday, April 06, 2007 - 06:52 pm, by:  Joel Moore (Ttsoai2ei2) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
STOCK as in completely STOCK NO STEEL WHEELS/FLOWED?
Brendan Hax
JZX90 Chaser Tourer-V
Friday, April 06, 2007 - 06:59 pm, by:  Brendan Hax (Chaser_94) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The turbo's are as they left the factory mate, that's what he means by stock.
Friday, April 06, 2007 - 07:08 pm, by:  Daniel Clarke (Dieseltrain) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Stock Ceramic Turbos! Stock DUmp pipes, Standard ECU( Greddy FCD), Standard Stall convertor! Full Interior!
Race weight today was 1710kg's.
Mt ET Street Tyres @ 18psi. Boost 17.8psi.
All i can say is WOW!!!
Daniel Trivuncevic
Friday, April 06, 2007 - 09:16 pm, by:  Daniel Trivuncevic (Madm0nk) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maurice wont be happy! hahaha
Friday, April 06, 2007 - 09:19 pm, by:  Daniel Clarke (Dieseltrain) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Haha Maurice = OWNED!
Gary Morriss
Friday, April 06, 2007 - 09:37 pm, by:  Gary Morriss (Gaza) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Daniel ..Excellent stuff mate,awsome time.
Mt ET Streets make a difference then.
Byron Clarke
VVTi Turbo Manual
Reg: 12-2006
Friday, April 06, 2007 - 10:07 pm, by:  Byron Clarke (Byron) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wish I could go have a turn at WSID. What do you have to do to get involved?
I'd be embarrased about getting a pathetic reaction time...
BTW Congratulations Daniel. Makes me proud to have the same last name ahahaha
Friday, April 06, 2007 - 10:12 pm, by:  Daniel Clarke (Dieseltrain) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Clarke FTW!!!!!
Australian Standard Helmet!
Long Pants, long Sleeves, Enclosed footwear!
Your car, $45 and have a good night.. OH and about 20L of fuel in the tank so you daont have starvation issues below 10L..
Cheers!
Byron Clarke
VVTi Turbo Manual
Reg: 12-2006
Friday, April 06, 2007 - 10:23 pm, by:  Byron Clarke (Byron) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
CLARKE
just a few q's: 1. does $45 only get you 1 run?
2. Does everyone warm up they're tyres just before the run
AND FOR MANUAL OWNERS
3. What would be the best way to take off in a manual
4. When is the best time to change gear? Redline or when boost expires?
Sorry for all the q's but i find it interesting.
USDM 2J camshafts installed!
Friday, April 06, 2007 - 10:32 pm, by:  Cihan Aday (Cihan) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Daniel Clarke wrote on Friday, April 06, 2007 - 09:19 pm:
Maurice = 12.74, 2.00 60' at 110MPH+
Maurice + Micky Ts + USDM camshafts = 12.1-12.2, 1.7 60' at 112MPH+
:-) FTW
Putting aside the friendly competitiveness, bloody fantastic work Daniel, very impressive!
Jeff Smith
TT Limited
Friday, April 06, 2007 - 10:34 pm, by:  Jeff Smith (Mozzie) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Here is some pic's from my mobile phone
Next Pic is Daniel's 12.478 launch
Ben's burnout
Rob Andreacchio
Supercharged VT Calais & 1991 JZZ30
Reg: 01-2005
Friday, April 06, 2007 - 10:35 pm, by:  Rob Andreacchio (Reepa) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I had a run @ 109mph with a 13.76 back when I was making a 100kw or so less.... LOL
That could spell trouble for Maurice! ;)
Jeff Smith
TT Limited
Friday, April 06, 2007 - 10:44 pm, by:  Jeff Smith (Mozzie) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Byron Clarke wrote on Friday, April 06, 2007 - 10:23 pm:
1.$45 for the whole night.
2.everone warms up but you don't have to if you don't want to.
3.Trial and error mate
4.Redline and it's trial and error
Have a go and let us know when you are thinking of heading out there and some of us will turn up for support.Don't worry about the time you might pull,It's all abought having a go.Once the 1st pass is out the way it's plane sailing from there.Then like most of us,You will be hooked on drag racing.
Byron Clarke
VVTi Turbo Manual
Reg: 12-2006
Friday, April 06, 2007 - 11:16 pm, by:  Byron Clarke (Byron) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Jeff, big help mate. Yeah I'd prefer to go there with you guys. I got Mondays and Sundays off work are there often Soarer Central meets there because I'd like to meet the gang.
Friday, April 06, 2007 - 11:35 pm, by:  Benny Gammelmark (Oldfield) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not that often but once in a while. It's usually on Wednesdays though.
Jeff Smith
TT Limited
Friday, April 06, 2007 - 11:37 pm, by:  Jeff Smith (Mozzie) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Byron Clarke wrote on Friday, April 06, 2007 - 11:16 pm:
Off street drags are held on wednesday nights,Starting time 5pm to 10pm.
As for soarer meets,Just say you are going abought two weeks in advance and we will turn up.
http://www.wsid.com.au/MajorEvent.asp?Event=Wicked&Page=Information
Blake Gloyn
manawatu
soarer JZZ30 TT
Saturday, April 07, 2007 - 07:17 am, by:  Blake Gloyn (Blakenz) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
awesome time. unbelievable launch!!! well done.
Saturday, April 07, 2007 - 07:39 am, by:  Daniel Clarke (Dieseltrain) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cihan, I ran 12.79 @ 110.5mph on street rubber with a 2.0 60 footer also!
As your ET comes down with the 60 footers coming down, the MPH drops also! Wheelspin tends to allow you to run a higher mph but robs you of ET.
Chris Davey
Corona
Saturday, April 07, 2007 - 08:24 am, by:  Chris Davey (Chris_davey) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
awesome stuff Daneil! Also only .024 off the stock ct12a record all together. Have to do that quick though as the cressida is apparently coming out with 20psi and a 75 shot next time!
How did Ben go as well?
Bill Bogiatzis
Saturday, April 07, 2007 - 03:06 pm, by:  Bill Bogiatzis (Boggie23) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
LoL who was the driver that you were up against Dan??? Was he in a shopping trolley or something.
I shouldnt laugh cause that is probably how fast I would go.
Saturday, April 07, 2007 - 07:31 pm, by:  Callum Finch (Sigeneat) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wow thats some good results on stock dump pipes and turbos o.O
Saturday, April 07, 2007 - 09:24 pm, by:  Daniel Clarke (Dieseltrain) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bill, an XR6 Turbo with 265rwkw. He almost kissed the wall Hard on that run! But he did run a 12.8 beforehand!
Chris, Probably hit the strip on Wed night if weather is good! Even if i could clinch that one for a split second!
