David Ross
TryHard Victoria one single turbo VVTi and one TT
Posts: 132 Reg: 08-2005
Goo Roo Victoria Active V8 and a Factory Manual XF.
Posts: 2178 Reg: 07-2005
| AWESOME.  |
Nayr Civoknar
TryHard Victoria JZZ30
Posts: 178 Reg: 01-2007
| wow, well done! post pics of your car and engine bay! or else well have to ban you  |
Gary Morriss
DieHard SA TT
Posts: 616 Reg: 07-2005
| Bloody great rosso Nayr..there's plenty of pic's of David beast on the forum. |
David Ross
Posts: 133 Reg: 08-2005
| Given that is on only 25psi, and we have forged pistons, H-beam rods, nitrited and balanced crank, we should be able to put 30psi into it without issue. Should be able to get 600+ before the turbos run out of puff.
Nayr Civoknar
Posts: 179 Reg: 01-2007
| rofl, the pussy shaver!  |
Joel Moore
TryHard SA 91 Soarer TT
Posts: 182 Reg: 10-2006
| Dave, its Joel, the young fella that chewed your ear off at the DA. Thanks for answering my questions and the tickets! |
DieHard Victoria JZZ30
Posts: 648 Reg: 07-2005
| looks like its going very well david! top work!! i guess the 97 soarer is retired from track work now? |
David Ross
Posts: 134 Reg: 08-2005
| The '98 is having the (bolt-in) roll cage removed and then in for a bit of a body tidy up, and then it's fully retired. |
David Hill
Tinkerer SA V8
Posts: 12 Reg: 03-2007
| What a machine! P.S. Thanks also for the tix. |
Posts: 651 Reg: 07-2005
| nice pick of um...........you car.... http://www.nissansilvia.com/forums/index.php?s=06835318e5a391bcc595b445a1e921d1&act=attach&type=post &id=80141 that is the kinda stuff that should be in the eye candy! |
Shane Crichton
TryHard NSW Cressida Turbo
Posts: 138 Reg: 03-2006
| david i would have more conidence in your package, we ran 32 psi on a factory engine with a 40 shot of nos for 18 months and never had an issue, the last couple of months before we took the engine out to upgrade to a built 1.5j we ran 35- 37 psi through a garret GT51R and still had no issues, good fuel and a good tune you will have no problems shane |
Byron Clarke
TryHard NSW VVTi Turbo Manual
Posts: 180 Reg: 12-2006
| Can you please make my car that fast? |
Simon Triantafillou
Goo Roo NSW Soarer Turbo
Posts: 1093 Reg: 07-2005
| Power doesn't always equal fast... I've got 383kW at the rear, but Daniel Clarke is half a second quicker down the quarter than I am. He runs stock turbos and auto box, I run a 2JZ with massive single turbo and manual box. |
David Ross
Posts: 138 Reg: 08-2005
| Once it comes back from Adelaide and we set the anti-lag (can use it to get 1.5 bar of boost at 2,000rpm), launch and traction control (all in the MoTeC) set up, we will pop out to calder to see just how fast it is in a straight line. |
Shane McInnes
Goo Roo NSW JZZ30 GT-TL Manual
Posts: 1024 Reg: 07-2005
| Yeah but but look at your MPH Simon compared to Daniel. Technically your car would run 10s, With slicks and the right launch. |
Posts: 1793 Reg: 03-2006
| Simon, Ive gone 12.4 which is almost 1 second faster.... Its all about traction, Tyres and setup Which we dont have to talk about as we know the end result which Shane has mentioned |
Shane Bradley
Tinkerer WA Supra JZA70 LTD
Posts: 66 Reg: 11-2005
| Jesus christ, highly impressive figures mate! What turbo setup does it run? |
Chris Davey
Goo Roo QLD Corona
Posts: 1351 Reg: 07-2005
| I will make my prediction for trap speed of 141mph ET could be anywhere between 12.5 (supra style ) or 9.5 if you nail the launch. Info. on turbo and ecu setup would be good  |
David Ross
Posts: 143 Reg: 08-2005
| If you are asking about my setup: Engine: 3 litre bottom end, forged pistons with h-beam rods and bolt kit, 1.5mm HKS steel head gasket, 1mm oversize stainless valves, ported head, 2 x HKS GT2835 turbos, HKS 264 intake and exhaust cams, HKS intake/exhaust cam gears, stainless exhaust manifold, modified inlet manifold with custom plenum chamber, 100mm throttle body, 6x 700cc injectors, 6x 550cc secondary injectors, MoTeC ecu, CDI ignition, HKS external wastegate, HKS drag-type front-mount intercooler, GREDDY blow off valve, 2x Bosch external fuel pumps, 1x high flow in-tank fuel pump, surge tank, engine oil cooler, power steering oil cooler MoTeC Traction and Launch Control Suspension/Driveline: Supra 4 spot brakes on front/2 spot on rear, stainless steel brake lines, Cusco strut bar, Getrag 6 speed, Exedy ceramic triple plate clutch, TRD locker diff, JIC adjustable coil-overs Body/Interior: Auto Meter monster tacho, shift light, Momo steering wheel, Aero mirrors, 2x Bride seats, 6 point roll cage Performance: 526.9 kWs (706HP) at the wheels (approx 800 at flywheel) |
Chris Davey
Goo Roo QLD Corona
Posts: 1353 Reg: 07-2005
| thanks So basically kit and kaboodle  |
Posts: 1865 Reg: 03-2006
| David, Thats an Awsome package. Congrats on the Dyno figures also, Bloody Awsome Im with Chris, this thing should run over 135pmh easily and run some low to mid 10 second passes. With some more time behind the wheel it should run into the 9's and over 145mph. Good luck and keep us updated! |
Shane Bradley
Posts: 67 Reg: 11-2005
| What fuel are those figures with? |
David Ross
Posts: 144 Reg: 08-2005
| We are using Sunoco but at only 25PSI we could probably be using Shell 100 (I think). |
Richard Johnson
TryHard Florida, USA SC300 1JZ-GTE Swap
Posts: 235 Reg: 06-2006
| i want engine pics, now! |
Shane Crichton
Posts: 141 Reg: 03-2006
| is this karl hardys old car? at the weight this thing is you would need 830 rwhp to run 145 mph |
Goo Roo Victoria Twin Turbo
Posts: 1345 Reg: 06-2006
Shane Crichton wrote on Wednesday, May 16, 2007 - 02:10 pm:is this karl hardys old car?
Uhuh.  |
