  SoarerCentral * General Soarer Chat * Cressida into the nines Previous Previous    Next Next
Shane Crichton
Cressida Turbo
Monday, May 21, 2007 - 09:03 am, by:  Shane Crichton (1jz747) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
HI all
on the weekend at the sport compact meeting the cressida had a top day.
10.009 at 146 mph smoking the tyres in 2nd and 3rd
10.15 at 147 mph smoking second and third
10.27 at 146 again smoking the tires even after taking 1 psi out of the tune
took an additional 3 psi out of the tune back to 24 psi
it worked with us running a pb of 9.915 et at 149.9 mph even with a lacklustre 1.777 sixty foot after the car had 1.5'd earlier in the day.
we broke the sprag for second gear on that pass and ran all eliminators as a 2 speed only having 1st and 3rd gear. the car still ran low tens 10.27 at 147 with no second gear.
we won the S/RWD class and reset our own national record to 9.915 at 149.9 mph.
massive thankyou to justin gregory from BLACKTRACK performance dyno centre (formerly rx engineering), MV automatics, Premier exhaust, and PRO COAT.
we are looking forward to jamboree, we will have our front runners and glass bonnett by then which will drop the wieght of the car fom 3400 pounds to min wieght of 3100 pounds, the front half of the cage will be going in aswell.
we know there is a 9.3 in the car as it sits so hopefully with a sticky willowbank track we will see it happen.
cheers
shane
Christian Molenda
T
Monday, May 21, 2007 - 09:26 am, by:  Christian Molenda (Christof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Congrats Shane. Good to see those times are still coming down.
Monday, May 21, 2007 - 10:46 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sounds like you had a pretty fun day out.
Aka Abedin
91 G-TT, 93 GTL 31
Monday, May 21, 2007 - 11:05 am, by:  Aka Abedin (Soarer_91tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well done and congrats.
Braden Murdoch
Cressida 1JZ TT
Monday, May 21, 2007 - 11:14 am, by:  Braden Murdoch (Ribfeast) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Very impressive to watch :-)
http://homepage.mac.com/rib_feast/1jz747_9.95_LQ.wmv
Joe Radisic
2JZ GTE & TO4Z
Reg: 10-2006
Monday, May 21, 2007 - 12:13 pm, by:  Joe Radisic (Joe) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Fantastic work well done!!
Luke Nieuwhof
Monday, May 21, 2007 - 01:45 pm, by:  Luke Nieuwhof (Luke_nieuwhof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Congrats Shane. The ultimate sleeper.
Monday, May 21, 2007 - 05:37 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Conagrats Shane:-) Thats an awsome result.
Blake Gloyn
manawatu
soarer JZZ30 TT
Tuesday, May 22, 2007 - 11:14 am, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
great effort shane. good to drop into single figures after being so close fo quite a while. well done.Is your fibre glass bonnet being custom made or is someone producing them commercially.?
Mark Ribbans
UZZ-031 V8, 1972 Mazda RX2 Coupe, TE Gemmy
Wednesday, May 23, 2007 - 12:37 am, by:  Mark Ribbans (V8gtsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey in that vid, looks like the Rx3 smoked him off the line.. Pity you can't see the end, i assume the Cresida won?
(i dont have sound on this PC atm if it is really obvious by the way)
Shane Crichton
Cressida Turbo
Wednesday, May 23, 2007 - 11:21 am, by:  Shane Crichton (1jz747) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
it wasnt a elimination it was a qualifier so i let the other guy go and just focused on getting a good launch, and i went flying past the rx3 at the 1000 foot mark
Mark Ribbans
Wednesday, May 23, 2007 - 12:04 pm, by:  Mark Ribbans (V8gtsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ah OK, man it must be tempting to nail it every time though.. Dont think i could resist! :-)
