read up on this and need: Boost Tee. I recommend Turbosmart Incabin Boost Tee. $175 Turbosmart TT boost adapter. $39 Cutters to cut hose BoostGauge. I recommend Splitfire Vac/Boost $70
where in perth can i get these and approximate pricing? also the boost to set it at?
Monday, September 26, 2005 - 03:19 pm, by: James Harris(Haro)
I was under the impression that in-cabin boost controllers are illegal ? But , who knows what is and what isnt illegal these days, i think it just depends on the police man.
Anyways, normally i just set the boost and forget about it, your BEST boost controller is your right foot.
But they all do basically the same thing, its just a matter of finding someone with tiny hands to get to all the lines / nipples...
good luck with which ever you choose to get, but have a read of the forum link that the guy posted in my reply.
Wednesday, September 28, 2005 - 01:58 am, by: Paul Brockbank(Brockas)
You can't wind down boost lower than stock as the wastegate actuator controls this.
The boost controllers leak air from the wastegate pressure lines to 'fool' the wastegate into believing only a certain amount of pressure is being generated by the turbos.
I will have a GFB bleed valve for sale in 5-6 weeks if your interested. Will probably let it go for around $50...
