  SoarerCentral * General Soarer Chat * Who has aftermarket wheels on their UZZ31? Previous Previous    Next Next
Chris Davey
Corona
Wednesday, August 15, 2007 - 01:29 pm, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If so, what are you doing with your stock 15 X 6.5" wheels? Please see this thread
https://soarercentral.com/sc-forum/messages/291/180987.html
Urgently needed to race at Jamboree next weekend. QLD definitely preferrable. Other soarers may have these 15's as well but I don't know what models?
Put a post in here as I don't think many people look in wanted section.
Wednesday, August 15, 2007 - 01:56 pm, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ashame you aren't in Auckland - I have a nice set sitting in the garage gathering dust.
Chris Davey
Corona
Wednesday, August 15, 2007 - 02:03 pm, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
aah so yours would be jzz31 ones then?
The other set I have found are in WA so I think you are still closer than them however international freight probably isn't too cheap :-(
Chris Davey
Corona
Thursday, August 16, 2007 - 01:39 pm, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
anybody else? VERY urgent!!!! jzz31 as well!!!
Luke Nieuwhof
Thursday, August 16, 2007 - 02:01 pm, by:  Luke Nieuwhof (Luke_nieuwhof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Chris, why those wheels in particular? Supra rims might be a better choice as you can fit a wider tyre.
Chris Davey
Corona
Thursday, August 16, 2007 - 02:07 pm, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They are 16X8 and then I would need to run 255/50/16's which I am not sure will fit in the rolled guards of my corona however I know that a 15X6 with 225/60/15 fits so a 15X6.5 with a 235/60/15 should fit too as there is minimal difference.
Don't want to buy wheels that don't fit basically :-)
Tai Johnsen
UZZ31 - V8
Thursday, August 16, 2007 - 02:30 pm, by:  Tai Johnsen (Privatejohnsen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Chris,
I have some stock 16's from a late model TT like this (not actual rims)
Not sure of the width, but your welcome to come and see if they fit.
Chris Davey
Corona
Thursday, August 16, 2007 - 03:05 pm, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Tai. Only issue is my car is unregistered so I can't just drive it down to test out. Thanks anyway.
Looks like I "may" have found some rims. 15X7" +35 offset (hopefully won't be too much, will measure tonight)
Thanks to all anyway :-)
Chris
Friday, August 17, 2007 - 06:53 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ah well Chris, if you do want me to investigate international postage, you can have mine for $100AU + whatever it costs to get the tires off them and post them. As you say though, would probably end up costing a fortune as it'd be something like 35kg's worth.
Bruce Shepherd
4.0 GT Limited
Friday, August 17, 2007 - 10:02 pm, by:  Bruce Shepherd (Shepo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Chris
I have a set of 15's
Bruce
Friday, August 17, 2007 - 10:32 pm, by:  James Johnson (Jamesy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
worst thing about v8 15" wheels is that i have seen nicer looking spew than those things
Chris Davey
Corona
Saturday, August 18, 2007 - 10:39 am, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks but all sorted now. Just picked up some 15X6.5" wheels +45 offset from
www.importbitz.com.au. Highly recommend John. He is an absolute champion!
Stefan Kjellberg
Soarer V8 Ltd
Tuesday, August 21, 2007 - 10:56 pm, by:  Stefan Kjellberg (Stefank) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mine came with 15" LS400 wheels on it. I soon picked up 4 16" supra wheels with brand new tyres on ebay for $280. Sold the ls wheels for $190.
That was 16 months ago and the supra wheels and tyres still going strong.
Wednesday, August 22, 2007 - 06:37 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, I do like my Supra 16's - not a big fan of large diameter wheels, but like chunky wide tyres, so the Supra's suite me fine.
