  SoarerCentral * General Soarer Chat * Legalities for mods Previous Previous    Next Next
Tom McGruther
Soarer GTT
Tuesday, October 04, 2005 - 04:57 pm, by:  Tom McGruther (Bigcheese82) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey guys just a couple questions:
what are the legalities with fitting a gauge in your car? someone said it needs to be equal to or lower than your dash. if this is so, why do i always see them down the dash and up the pillar?
also,
someone posted that automatic boost controllers are illegal to use. is this true or a wives tale?
Paul Brockbank
Wednesday, October 05, 2005 - 01:31 am, by:  Paul Brockbank (Brockas) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Depending on what state your in (talking from WA experience) any type of aftermarket boost controller is illegal.
Over here it aint a big deal, get a defect notice, take it out, go over the pits, get on with life $50 poorer...
Gauges must not obstruct your field of vision and must be secured. A-Pillar gauges are illegal here (if not permitted), and will get you a defect notice if you dont have a permit.
Wednesday, October 05, 2005 - 10:03 am, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Boost controllers are illegal? o.O
Are they Permit-able?
Tom McGruther
Soarer GTT
Wednesday, October 05, 2005 - 10:29 am, by:  Tom McGruther (Bigcheese82) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
really? ouch. amazing you can buy them everywhere. i think i will blast an email to dept transport on that matter to be safe.
also,
is it illegal to remove the sound deadening on the underside of the bonnet?
Samantha Hornby
Soarer 2.5GT Twin Turbo
Wednesday, October 05, 2005 - 10:40 am, by:  Samantha Hornby (Soarer_chick_1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Someone told me racing pedals are illegal on street vehicles too - only to be used on rally cars? Is that right?
Shane McInnes
Wednesday, October 05, 2005 - 10:55 am, by:  Shane McInnes (Soarin_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
in NSW i believe aslong as the gauge is below the steering wheel it is legal.
Tom McGruther
Soarer GTT
Wednesday, October 05, 2005 - 12:29 pm, by:  Tom McGruther (Bigcheese82) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey guys,
here is the link to legalities as seen by QLD Department of Transport.
http://www.transport.qld.gov.au/qt/LTASinfo.nsf/index/vehicles_modifications
Tom McGruther
Soarer GTT
Wednesday, October 05, 2005 - 12:30 pm, by:  Tom McGruther (Bigcheese82) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
to be more precise:
http://www.transport.qld.gov.au/qt/LTASinfo.nsf/ReferenceLookup/Modification_Jan05v2.pdf/$file/Modification_Jan05v2.pdf
Ryan Rankovic
Soarer TT GT-TL
Wednesday, October 05, 2005 - 02:01 pm, by:  Ryan Rankovic (Ryan1j) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
in vic its illegal to have mechanical gauges mounted inside the cabin......electronic gauges are fine however.
UZZ32 ( V8 )
Wednesday, October 05, 2005 - 02:22 pm, by:  Perry Morgan (Uzz32) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oh because that makes perfect sense doesn't it Ryan.
Ryan Rankovic
Soarer TT GT-TL
Wednesday, October 05, 2005 - 03:05 pm, by:  Ryan Rankovic (Ryan1j) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
well you arent allowed to run any oil or vac lines into the cabin for safety reasons.... (im pretty sure)
imagine you had a mechanical oil pressure gauge and the line came out of the gauge and you have nice hot oil everywhere.
i think
Peter Burrett
2.5 VVTi ST
Wednesday, October 05, 2005 - 03:10 pm, by:  Peter Burrett (Burrett) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
.....Ryan, you could just pull the vac line off and hoover the oil away.......
Wednesday, October 05, 2005 - 06:38 pm, by:  Morgan Cross (Morgan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Good point Peter.
Gauges have to be in line with or below the dash, anyone you see with gauges up the A Pillar are just asking for a massive defect.
Legalities aside, they are just plain tacky.
