  SoarerCentral * General Soarer Chat * Confirming Milage on an imported Soarer Previous Previous    Next Next
Dale Holan
Alberta
2.5 GTT L
Reg: 06-2007
Friday, September 14, 2007 - 01:39 am, by:  Dale Holan (Xtrax) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm wondering if there is an easy or not so easy way to confirm the mileage on my TT Soarer? It ODO reads just over 43,000 km's. How can I tell if this is true?
Dave Billings
Louisiana
SC 300, Manual Transmission
Reg: 06-2007
Friday, September 14, 2007 - 01:43 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I was wondering- how do they turn them back on digital odometers, is it possible?
Dale Holan
Alberta
2.5 GTT L
Reg: 06-2007
Friday, September 14, 2007 - 01:48 am, by:  Dale Holan (Xtrax) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well is the info saved in the ECU or in the dash it self? Either way a switch out could be possible. Can they just reprogram it to read a different number?
Dale Holan
Alberta
2.5 GTT L
Reg: 06-2007
Friday, September 14, 2007 - 01:50 am, by:  Dale Holan (Xtrax) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
see if you look at this link the broker states that the "mileage is believed to be inaccurate"
http://www.importconcern.ca/perl/b_list.pl?12015
Dave Billings
Louisiana
Reg: 06-2007
Friday, September 14, 2007 - 02:00 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That is one ROUGH looking "19000 km" Soarer!!
Dale Holan
Alberta
2.5 GTT L
Reg: 06-2007
Friday, September 14, 2007 - 02:05 am, by:  Dale Holan (Xtrax) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
maybe it rolled for the other 100,000 kms.
don't worry I'm not buying it. I have mine I just wanted to confirm what my odo says.
Dave Billings
Louisiana
Reg: 06-2007
Friday, September 14, 2007 - 02:29 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Looked like it was pulled by a mule!!
Friday, September 14, 2007 - 06:28 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Looks more like 190,000km's++ to me.
Friday, September 14, 2007 - 07:48 am, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Its VERY easy to turn back the digital reading on the odometer.
You can either set it to 0 or some other arbitrary number.
Of course, the right tools are required, but it happens all the time and the odometer is not an accurate measure for how good the car is. Get a mechanic to check over it.
Dale Holan
Alberta
2.5 GTT L
Reg: 06-2007
Friday, September 14, 2007 - 07:51 am, by:  Dale Holan (Xtrax) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is there a way for me to get an accurate check of the milage on my own?
Benjamin Burgess
Toyota Soarer GT-TL, Toyota Corolla Conquest
Friday, September 14, 2007 - 07:59 am, by:  Benjamin Burgess (Jampac) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Before compliance there is usually stickers placed around the car when services take place, and they usually fill in the odo reading when it's done. You can find these stickers placed behind the fuel flap, in the driver door sill and on the under side of the bonnet. The fuel one is usually a good one as they put all the fuel filter replacement records there.
Dale Holan
Alberta
2.5 GTT L
Reg: 06-2007
Friday, September 14, 2007 - 08:04 am, by:  Dale Holan (Xtrax) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No such luck. But good Ideas, I had this brought straight over from Japan to Canada so I'm looking for something Japanese.
Luke Nieuwhof
Friday, September 14, 2007 - 01:53 pm, by:  Luke Nieuwhof (Luke_nieuwhof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dale Holan wrote on Friday, September 14, 2007 - 07:51 am:
Not sure, but depends why you want it.
Especially with imports I think you are better off buying based on condition rather than Ks. Have a look at wear on the interior, particularly on the steering wheel and this can give you hints on how much the car has been used. Check things like the scrape panel underneath the engine as well.
Murray Lund
Friday, September 14, 2007 - 07:10 pm, by:  Murray Lund (Murray) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Check wear on the pedals, seats, steering wheel etc. I'm looking more for a car that has been looked after than how many km's it has reputed to have done.
Ben Kelly
Lidcombe
v8
Friday, September 14, 2007 - 07:20 pm, by:  Ben Kelly (Ace) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i second Lukes and Murrays post, door sag can be an indicator on some cars too but i dont think soarers suffer from this(?). Drivers side seat wear is a good indication tho. If its a soarer and you are in doubt id say multiply the shown kms by at least 4. Being a 91 id take a guess and say err 240 000kms.
Friday, September 14, 2007 - 08:50 pm, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Condition of the interior is a good indicator of usage, but you are better off getting the engine, transmission, suspension etc checked by a mechanic for the common problems, as they can and have been known to creep up on cars even sub 100,000kms
Dave Billings
Louisiana
Reg: 06-2007
Saturday, September 15, 2007 - 02:58 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I replaced my door hinges a year ago because the sag was rubbing my ground effects. I never realized how heavy the doors really are!
