  SoarerCentral * General Soarer Chat * Thinking about turboing my 8! Previous Previous    Next Next
Nathan Taskis
Reg: 04-2007
Friday, September 14, 2007 - 05:47 pm, by:  Nathan Taskis (Lugemunky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Peoples...
I am thinking about putting a turbo in my v8 soar.. So i was just wondering what you guys think?! Also any help on what to look for etc. would be greatly appreciated.
Thanks.
Friday, September 14, 2007 - 06:55 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Use search.
UZZ32 ( V8 )
Friday, September 14, 2007 - 08:16 pm, by:  Perry Morgan (Uzz32) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Think about getting $15k outa the bank too while you're at it
It's an expensive dream.
Grant Rowan
jzz30 TT
Friday, September 14, 2007 - 08:46 pm, by:  Grant Rowan (Booster13psi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It may be worth looking at an under body turbo set up.
http://i.b5z.net/i/u/1473169/f/Press/stspes.pdf
Andrew Meiers
Friday, September 14, 2007 - 09:59 pm, by:  Andrew Meiers (Acmtt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Contact Peter Chriss on this forum as he has just done it.
Rainer Fritzsche
vvti manual
Saturday, September 15, 2007 - 07:23 pm, by:  Rainer Fritzsche (Ryner) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Grant Rowan wrote on Friday, September 14, 2007 - 08:46 pm:
That setup is seriously flawed. A turbo should be as close as possible to the exhaust manifold so as not to lose energy (heat). If you want to look at some properly engineered setups, you're better off looking in our own backyard.
They won't be able to help you with anything for the Soarer, but check out Air Power Systems for some well engineered kits.
http://www.airpowersystems.com.au
Sunday, September 16, 2007 - 02:21 am, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rainer Fritzsche wrote on Saturday, September 15, 2007 - 07:23 pm:
I wont get in to a debate about what is better/worse, however you will find rear-mounts a lot more common (especially in the drag scene) due to engine bay size restrictions; ie lack of.
Jeff Harper
UZZ32 Active V8
Sunday, September 16, 2007 - 07:26 am, by:  Jeff Harper (Jeffh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you are not looking for SERIOUSLY BIG power then rear mount is an excellent solution for the 1UZ as no exhaust manifolds need to be changed. Your only issue will be with lubrication both to and from the turbos.
The diff area has tons of room for 2 x small snails.
The compressed air can even be pumped by plastic piping to the intake. This aids the coooling effect.
There are many fine examples of this on road going vehicles, daily drivers.
It would have to be the most cost effective way to get the most bang for the least amount of bucks.
Of course, you will need an engine management system as the factory ECU would step in and kill off any gains.
$5000 should do it without an intercooler providing you can source everything and do it yourself.
Jeff Harper
UZZ32 Active V8
Sunday, September 16, 2007 - 07:33 am, by:  Jeff Harper (Jeffh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
In the Monaro article, I have to admit all that hardware hanging down is dumb, no need for that in a Soarer, there is tons of room to tuck it all up out of the way.
Mick Mielczarek
qld
v8
Reg: 07-2006
Sunday, September 16, 2007 - 02:41 pm, by:  Mick Mielczarek (Eta04) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have seen a good setup on your tube where the turbos fold around to in the front of the engine!!!
One thing i must say is you must have really deep pockets and think serious before you take on the commitment because there are some many hidden costs envolved!!!
I would more allow for $20,000
Rainer Fritzsche
vvti manual
Sunday, September 16, 2007 - 09:48 pm, by:  Rainer Fritzsche (Ryner) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Making big power and having a response engine can be, and often are two completely different things. - I know I rather have the latter. - Torque as low as possible in the rev range and an engine that's responsive to throttle input to be more specific.
I've haven't read a lot about the rear mounted turbo setups, to be honest, because I think they'd be horrible to drive on a street car, not too mention all the potential dramas. - oil feed & return, coolant feed & return, potential damage to piping & components due to the location etc. The biggest point, I can't believe anyone's hasn't brought up, is something too many people harp on about in regards to front mount intercooler systems......excessively long pipework. Introducing such a great length of extra pipework on both the exhaust and compressor circuits has got have a negative impact on engine repsonse.
I much prefer turbos to superchargers, but if V8's are your thing and you want forced induction, i recon you'd be far better off with a blower, if you're on a budget. - even a centrifugal blower. cringe......no offence to anyone who has one....
Luke Nieuwhof
Monday, September 17, 2007 - 01:43 pm, by:  Luke Nieuwhof (Luke_nieuwhof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rainer, rear mount systems are quite popular on some big cube cars. They already have the torque down low so lag is not as much of a problem. Obviously quite good for drag racing too where you can keep it up in the power band.
I believe in regards to piping etc it is just as simple as an underbonnet job. While it is longer it can be a lot simpler with more room.
So while rear mount (I still smile when I type that) would make no sense on a 1JZ for instance, on a V8 it could be a bit better, and if you have no room, well you do what you have to :-)
