  SoarerCentral * General Soarer Chat * My Qtr Mile and Trans issues Previous Previous    Next Next
Christian Molenda
T
Friday, October 19, 2007 - 07:10 am, by:  Christian Molenda (Christof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hello
Well last night i went to test and tune. After much messing about we got there half way into it and didnt have much time to get many runs in. The plan was to rotate tyres between me and my mate. As soon as we got there we both lined up to race. Me still on my 20's him on the et streets.
As i was on the 20's i decided not to waste my time stalling the car up and just took off normally. This resulted in a 2.221 60ft. just as the car got into 3rd gear it started feeling as if something was slipping (not sure if its the converted not locking up or 3rd gear killing itself) and the revs felt like they were dropping off and picking up and the car not picking up speed
anyway i kept on the gas knowing that this was going to be my only run for the night and resulted in trapping 116.25 mph. Im sure i lost 2 or 3 mph because of the issue. It felt like it just stopped pulling.
anyway end result was 12.67 and smoke bellowing out from under the car on the way back to the pits.
i let it all cool down and took it easy on the drive home.
Has anybody else had this problem?
Also should i hook up a manual lockup switch, would this possibly fix the prob?
guess i should call mv's to see if they have any ideas.
Friday, October 19, 2007 - 09:37 am, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There are some diagnostics that you can run on the auto box without any plug in tools to give you an idea what is happening.
The electronics in the gearbox also allow for anyone with the appropriate Toyota plug-in tool thing used for diagnostics to find out exactly what part of the box is failing. At least thats what im lead to beleive ;)
I'm thinking clutch packs are giving up the ghost, however not sure about the smoke o.O
What colour/smell is the transmission fluid? If its burnt at all then perhaps start with a flush. The solenoids and other parts are very fussy if they dont get nice clean fluid! ;D
One of the first things i had to do to my car after i bought it was swap out the transmission; its a pain in the ass!
With the sort of power you would be putting out (Going by mods in profile..) it would sound likely that something is not able to hold the power anymore. MV should be able to give you some advice at least! ;D
Cara Joseph
skyline T
Reg: 04-2007
Monday, October 29, 2007 - 12:48 pm, by:  Cara Joseph (Carasky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
christian unless you have a fully built trans the enividible is happening and your trans is caput.
Monday, October 29, 2007 - 01:47 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Christian Molenda wrote on Friday, October 19, 2007 - 07:10 am:
That would be the convertor locking up... But it shouldnt take long for it to lock right up and the car to start moving again....
Could be the lockup clutches were being fried by the power and more than likely Cara is correct. The smoke is probably the clutches burning or the oil burning from the excessive heat caused by slipping clutchpacks.
ALot of people forget that while the Autos with a shift kit might be good, the wont hold for long at 270+rwkw. Specially if they are getting close to the end of their life! On a new box they will prob last a while at that power output with a shift kit and trans cooler... But on a Well USed Box, it will only finsh the job quickly.
With that said though, Trapping 116mph is pretty damn good! Ben was running in the 118's with more power and on ET Streets.
Maybe there is nothing wrong with the box itself, just the oil being cooked! INvest in a some Castrol TRansmax Z oil or some Redline Synthetic racing Oil!
Better Oils will help raise the boiling point of the Fluid which will allow the clutches to take more punishment.
Cara Joseph
skyline T
Reg: 04-2007
Monday, October 29, 2007 - 02:05 pm, by:  Cara Joseph (Carasky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Transmax Z is the go for sure.
Christian Molenda
T
Monday, October 29, 2007 - 02:28 pm, by:  Christian Molenda (Christof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i think my mph would have been higher without the trans issues. (atleast 118mph)
I was thinking it may have been the converter trying to lock, but it just did not happen. it did not seem like the it was actually slipping as the revs werent raising. I will flush the trans soon and see if that makes a diff. Will also get a temp guage whilst at it.
im looking forward to getting that 11 second time slip.
www.etuner.com.au
Monday, October 29, 2007 - 04:50 pm, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Christian, you could cut and connect a 10k resistor to the SL (solenoid) pin from the ECU to ground. That'll get rid of lockup if want to try it out.
Once power levels go up it feels as if the car slows acceleration when its trying to lockup. Happens at about 130-140kph. Since its been unlocked in 1st and second for at least 10 seconds at full power the trans fluids already hot.
Because trans fluid expands when its hot, the pressure check valve on the trans housing can open and dump fluid to relieve pressure. If its coming out in 3rd, its most likely pouring out onto the exhaust piping and causing the smoke. Happens all the time on the dyno, especially if theres no trans cooler, the lines to cooler are restricted/bent or the fluids overfilled.
Christian Molenda
T
Monday, October 29, 2007 - 07:20 pm, by:  Christian Molenda (Christof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey mate
Sounds exactly like what you just mentioned. I will give it a go next time im at the track. I will also give the trans a propper flush and use some good fluid.
Thanks for your help as always.
Christian
Monday, October 29, 2007 - 10:02 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Np's, Hpefully its just in need of a good flush and some good fluid :-)
Good luck and keep us updated!
Benjamin Burgess
Toyota Soarer GT-TL, Toyota Corolla Conquest
Tuesday, October 30, 2007 - 09:05 am, by:  Benjamin Burgess (Jampac) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Daniel Clarke wrote on Monday, October 29, 2007 - 01:47 pm:
118.9mph to be exact :-) I think you'll find that it's not effecting your trap speed. After getting my box rebuilt I was expecting to come back and trap higher, but it wasn't much if any at all. The biggest gains I've gotten in trap was from letting the car cool down enough between runs. Also you'll find you'll loose a small amount of trap speed when using ET streets. I'd estimate you'd run a 11.6 with the right 60ft.
Tuesday, October 30, 2007 - 05:28 pm, by:  Maurice Diggler (Mau_rice) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cara Joseph wrote on Monday, October 29, 2007 - 12:48 pm:
Hahs, speaking from experience huh! I remember yours giving up after 1-2 days lol :-)
Christian Molenda wrote on Monday, October 29, 2007 - 02:28 pm:
I have the exact same problem, since fitting the cams and tuning it wont lock up, tries to but never does :-( It ruins my dyno runs and 1/4 :-( I'll get it sorted soon.
Tuesday, October 30, 2007 - 07:32 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Stick in a Manual, that will really FUBAR your 1/4 times :-)
Tuesday, October 30, 2007 - 10:02 pm, by:  Maurice Diggler (Mau_rice) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Haha, and my driveshaft! Feel the burn huh Shane! :-)
If/when I have R154, the day I get it is the day I sell off my MT's and do away with 1/4 and focus more on Phillip Island and Winton :-)
Wednesday, October 31, 2007 - 07:26 am, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Poor Shane,lol!!!
And yeah dude.. Stick shift and Circuit work FTW!
Shane Crichton
Cressida Turbo
Thursday, November 01, 2007 - 11:25 am, by:  Shane Crichton (1jz747) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i woudl actually advise against this.
dont run synthetic in your box unless its been fully built, synthetic oils are far harder on the trans than non synthetic.
it will run higher line pressure with synthetic than non, this will resulted in a busted box. if you run cheap ass valvoline dex3 and change it regularly it will slip before it breaks.
also, most synthetic dex 3 products are built with metal on metal thought process. it doesnt not factor in soft clutches. we are testing this at present with my box.
Thursday, November 01, 2007 - 01:13 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ahh ok, Thats the opposite of what i was advised.. Thats the way it goes :-)
Thursday, November 01, 2007 - 04:51 pm, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Toyota standard ftw?
Braden Murdoch
Cressida 1JZ TT
Thursday, November 08, 2007 - 02:50 pm, by:  Braden Murdoch (Ribfeast) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I asked the same question to Mike @ MV earlier this week.
Toyota Type IV if you have no shift kit
Dexron 3 if you have a shift kit
No fancy fluids - just use Valvoline etc etc
Friday, November 09, 2007 - 07:50 am, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It should probably be noted that (i am stating this without any actual knowledge of which fluid is better) if the guy who runs MV said that "x is better with a shift kit" he is probably referring to a shift kit manufactured by his company as opposed to one made by someone else. =P
Shane Crichton
Cressida Turbo
Friday, November 09, 2007 - 01:28 pm, by:  Shane Crichton (1jz747) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
callum, what does that have to do with the price of eggs?
dex 3 is probably the same price as toyota type 4, give or take $5. so what is the point of what you have just said?
the shift kit will prolong clutch life as they dont slip. dex 3 is like water compared to type4, so typ 4 is better standard boxes that slip like a bitch on gear changes
Sunday, November 11, 2007 - 02:34 am, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Shane Crichton wrote on Friday, November 09, 2007 - 01:28 pm:
WHAT THE FK ARE YOU SMOKING?!
All a stage 1 shift kit from Mr. MV does is increase the speed at which the box changes gears. This is done through a change in some valve. There is a guide somewhere that a guy wrote up on how you can do this yourself.
What i was trying to say is that dont assume that one kit is manufactured the same as another when you get to the kits beyond simple changes.
Make sense? It doesnt to me when i read back over the post but too bad =P
www.etuner.com.au
Sunday, November 11, 2007 - 10:02 pm, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think Shane means an egg is an egg, doesn't matter who you buy it from. In the same respect a shift kit is a shift kit, they all modify the pressure actuating valves (line, throttle and gear vavles) to achieve the desired result (faster shifts, better clutch clamp, you name it). Doing so negates the need for low viscosity transmission fluids like Toyota Type-IV which Toyota designed to accommodate their low pressure smooth shifts. It doesn't matter where you get the transmission 'shift kitted', the outcome is the same - Dex3 is more suitable.
Shane Crichton
Cressida Turbo
Monday, November 12, 2007 - 10:36 am, by:  Shane Crichton (1jz747) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Callum Finch wrote on Sunday, November 11, 2007 - 02:34 am:
if you dont make sense to yourself, how can you expect anyone else to understand what you are on about.
cihan is spot on.
Phil Gibson
'94 black/black UZZ31
Monday, November 12, 2007 - 02:11 pm, by:  Phil Gibson (Sciflyer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Its ok, Callum is just crapping on about something he knows nothing about...
Richard Johnson
Florida, USA
SC300 1JZ-GTE Swap
Tuesday, November 13, 2007 - 02:34 am, by:  Richard Johnson (92soarertt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My trans suffered the same fate..
3rd gear clutch packs are roasted. The rest will follow if you keep on it hard.
Raybestos makes a good performance clutch kit for the A340e, along with shims and MKIV A341e springs, will make it able to withstand a good 600whp once and a while. If your going to drag it every weekend, the only "automatic" fix is going to a TH400 or TH700R4. A full GM transmission conversion to hold 1000whp all day long costs around $3000usd. Rebuilding a spare A340e to hold 500whp costs under $1000usd.
