  SoarerCentral * General Soarer Chat * Ooooooooooooh, shiny :-) Previous Previous    Next Next
Ben Socratous
I am the fibreglass/kevlar/carbonfibre king!
Friday, October 19, 2007 - 06:53 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Project 1.5Jizzle is coming along nicely, albeit a bit slower than expected. New front and rear main oil seals are in, new water pump and timing tensioner. Now I just need the head to hurry up and come back and the real fun can start :-)
Brian Kelly
Colorado USA
Reg: 04-2007
Friday, October 19, 2007 - 07:00 pm, by:  Brian Kelly (Whereswaldo583) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
drool....
Friday, October 19, 2007 - 07:21 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Looks ghey!
Clayton Webb
'31 V8
Saturday, October 20, 2007 - 08:40 am, by:  Clayton Webb (Clackers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think Ben can host the next fix it day!
Cara Joseph
skyline T
Reg: 04-2007
Tuesday, October 23, 2007 - 11:03 am, by:  Cara Joseph (Carasky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
niiiiiiiiiiiice.
Ben Socratous
Monday, January 28, 2008 - 08:52 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Progress report #2
Excuse dodge phone pic!
Head is on, new manifold and turbo, oil sump assembly sourced and fitted, and the cam gears finally came back from the machinist :-)
Edward Salem
Aristo 3.0V TT
Reg: 01-2007
Wednesday, January 30, 2008 - 09:27 pm, by:  Edward Salem (Sydeward) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thats a big suction thing on the side there...
does it double up as a meat mincer?
Wednesday, January 30, 2008 - 11:28 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Looking good .. Although wouldnt you want the oil drain to be completly downhill? Not tryin to bend back upand then into the bottom?
Ben Socratous
Thursday, January 31, 2008 - 08:57 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oil drain is flat for the last part, but it will slope more downwards when the motor goes in and I have something to bind the line to.
