  SoarerCentral * General Soarer Chat * New soarer owner-Wanting to know where you buy new headlight globes.Melb Previous Previous    Next Next
Ben Mace
tt
Saturday, October 20, 2007 - 10:42 am, by:  Ben Mace (Macey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It has been covered iam sure but cant find where.I need new low beam globes and the globes for side indicater on the body for a RWC.Any one know where can get these. Cheers. Iam in Melbourne on Mornington Peninsula.
Ben
Saturday, October 20, 2007 - 11:45 am, by:  Mike Triggs (Mikeandimah) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You're right Ben, this topic has been covered many times.
In essence, the low beams are problematical, unless they have been changed when complianced or through SEVS. Some early ones were changed to 9006 (HB4) apparently while others appear to be 9005 (HB3). Ours is a personal import and so was not changed and takes the Soarer-unique 9005J which requires mods to a 9005. Take your existing globe(s) out and see what's written on them, as a first step. If they are Koito brand they might be 9005J.
Both HB3 (9005) and HB4 (9006) are readily available at auto parts shops. The mod to a 9005 to fit the 9005J space isn't difficult, just a pain. A Dremel-type tool is very handy, and having a 9005J to compare to is extremely helpful. The connector is also different, so you either need to modify the lugs inside the globe's connector section, or change connectors to the same type as the high beams (which on ours are straight 9005 (HB3), I've discovered).
Ben Mace
tt
Saturday, October 20, 2007 - 04:00 pm, by:  Ben Mace (Macey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike, Thank you very much mate.very helpfull.
