  SoarerCentral * General Soarer Chat * Boot Stops??? Previous Previous    Next Next
Francisco Valdivia
Wollongong NSW
Reg: 01-2007
Wednesday, November 14, 2007 - 07:51 pm, by:  Francisco Valdivia (Silvasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey everyone, I have renewed my gas struts in the boot and now the boot stays up, boy I miss it hitting my head NOT!
My problem now is, when I pop the boot, sometimes it lifts and opens with an unerving clunk, if I'm not quick enough to stop it.
Is there a way to stop this, or is there bump stops that can be fitted. I can't see where there would be one. Anybody???
Wednesday, November 14, 2007 - 07:57 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There supposed to be bump stops that sit on top of the arms behind the fuel tank cover. Perhaps they weren't refitted properly.
Your struts may also be over gassed, or made for the added weight of a spoiler (if you don't have one).
V8 Ltd manual
Wednesday, November 14, 2007 - 08:04 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The way they are supposed to work on any Lexus is that the boot pops clear but does not lift, then stays up when lifted by you. This is apparently so rain does not enter or your valuable goods not exposed to the world when you pop the boot from inside the car. So, your struts are over-gassed by Lexus/Toyota standards.
Francisco Valdivia
Wollongong NSW
Reg: 01-2007
Thursday, November 15, 2007 - 11:54 am, by:  Francisco Valdivia (Silvasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cheers for that.
Had a look. No bump stops.
