  SoarerCentral * General Soarer Chat * Hypertune f@%ked up my Soarer!!! Previous Previous    Next Next
Open in new windowArchive through December 10, 2007Jeff Smith45
Adam Chytra
Manual '31 V8
Monday, December 10, 2007 - 06:23 pm, by:  Adam Chytra (Soarpra) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And another one, a bit longer this time
http://www.youtube.com/watch?v=6BdClXuOX-M
Jeff Smith
GT30/37r Single T
Monday, December 10, 2007 - 07:04 pm, by:  Jeff Smith (Mozzie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Unreal!
Monday, December 10, 2007 - 08:33 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Excellant.
WSID on Friday Night ? :-)
Paul Gaspar
queensland
single turbo manual
Wednesday, December 12, 2007 - 06:29 pm, by:  Paul Gaspar (Speed) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm not sure how this set up will work as a T88 turbo requires very high revs to function properly which a standard V8 wont provide.
Luke Nieuwhof
Wednesday, December 12, 2007 - 06:32 pm, by:  Luke Nieuwhof (Luke_nieuwhof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
? Smaller engines need higher revs, a bigger engine doesn't need quite so many.
Ben Creswick
Wednesday, December 12, 2007 - 06:36 pm, by:  Ben Creswick (Turbo4l) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think with 4Litres it should come on boost ok.I think is requires exhaust gas to spool up the turbo not revs.(GTR's need to rev to get the exhaust gas happening)
Wednesday, December 12, 2007 - 06:55 pm, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That's right Ben. =D Two hundred points, alright!
Adam Chytra
Manual '31 V8
Thursday, December 13, 2007 - 03:52 pm, by:  Adam Chytra (Soarpra) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I suppose we could put a smaller turbo on ?????}
Luke Nieuwhof
Thursday, December 13, 2007 - 04:24 pm, by:  Luke Nieuwhof (Luke_nieuwhof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
noooo, don't listen Adam!!!! :-)
Adam Chytra
Manual '31 V8
Thursday, December 13, 2007 - 05:11 pm, by:  Adam Chytra (Soarpra) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don't worry, I wasn't!!!!!!
Phil Gibson
'94 black/black UZZ31
Thursday, December 13, 2007 - 05:16 pm, by:  Phil Gibson (Sciflyer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Revs have nothing to do with turbo function, a turbo only requires gas flow and heat, it doesnt care whether the engine is spinning at 3000rpm or 30,000... and generally speaking a 4 litre engine will spin it up better than a 3 or 2.5 litre will...
If its a stock internal engine you wont be running much boost, at least being a larger turbo it wont strangle the top end
Paul Gaspar
queensland
single turbo manual
Thursday, December 13, 2007 - 05:32 pm, by:  Paul Gaspar (Speed) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dont forget we are talking about a T88-38 which is a huge turbo. Out of interest what horsepower are you looking for ?
Adam Chytra
Manual '31 V8
Thursday, December 13, 2007 - 06:53 pm, by:  Adam Chytra (Soarpra) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Paul Gaspar wrote on Thursday, December 13, 2007 - 05:32 pm:
It's not that big
Adam Chytra
Manual '31 V8
Thursday, December 13, 2007 - 07:06 pm, by:  Adam Chytra (Soarpra) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Very low boost for the time being -about 7psi. We'll find out mid next week what she makes when it hits the dyno
Antonio Hunt
Reg: 11-2006
Wednesday, January 02, 2008 - 11:55 am, by:  Antonio Hunt (Carajo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
any updates on this beast
Adam Chytra
Manual '31 V8
Thursday, January 03, 2008 - 07:48 pm, by:  Adam Chytra (Soarpra) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
We're just tidying up a few loose ends this week, so it should be ready for the dyno when everyone opens back up next week
