  SoarerCentral * General Soarer Chat * Engine compression? Previous Previous    Next Next
Blake Davies
S A
lux
Sunday, April 13, 2008 - 02:08 pm, by:  Blake Davies (Boss_da_man) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hello
what is the normal Engine compression for 1JZ ?
has anybody done the Engine compression test?
cheers..
Shaun Chiew
Reg: 11-2007
Sunday, April 13, 2008 - 08:39 pm, by:  Shaun Chiew (Senk9) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Around 160-180 is normal if I recall, look for discrepancies between the cylinders moreso than the figure itself
Monday, April 14, 2008 - 08:36 am, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
160-180 what? o.O
Isn't compression normally expressed as a ratio?
ie, 10:1
Shaun Chiew
Reg: 11-2007
Monday, April 14, 2008 - 08:55 am, by:  Shaun Chiew (Senk9) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You're thinking of compression ratio, like they list on spec sheets ..
Compression testers give a readout in PSI for static compression ... Go to any workshop / wrecker and they'll test individual cylinders in this way ...
Luke Burt
Reg: 08-2007
Monday, April 14, 2008 - 08:56 am, by:  Luke Burt (Burt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not when doing a compression test
Compression test consists of your tester, then you unscrew a spark plug, and crank the motor(after removing fuel pump relay/fuse as you dont want any fuel in the cylinders, or the motor to fire up..), it will give you a reading for compression, the tester sits tight in your spark plug hole and as the piston comes up it will give you a compression reading in psi.
As stated above 160-180 is about ideal but it's more important to have consistancy accross the chambers, ie 174, 173, 178, 169, 150, 170 means you probably haved rings on piston 5.
Miles Baker
66 Mustang GT Convertible, 55 Chevy Bel Air, 69 Firebird 455, 73 Corvette 4sp T-Tops
Monday, April 14, 2008 - 10:48 am, by:  Miles Baker (Milesb) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Or it could mean that your coolant was too cold and your #5 conrod shrunk.
Monday, April 14, 2008 - 11:41 am, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
OIC now. =P
Monday, April 14, 2008 - 02:30 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Miles Baker wrote on Monday, April 14, 2008 - 10:48 am:
That reminds me, you should trim your bush in winter to make your deck look bigger.
Monday, April 14, 2008 - 04:30 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Scott Gates
Monday, April 14, 2008 - 04:46 pm, by:  Scott Gates (Scotty_001) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter, pure gold.
