  SoarerCentral * General Soarer Chat * Passengar Support Handle Previous Previous    Next Next
David Grab
T78
Reg: 01-2008
Thursday, April 17, 2008 - 12:01 pm, by:  David Grab (Blastedbyasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guy i dont know how this happened but it did. The bottom part of the passengars support handle (the handle on the A pillar) has come off and i have no idea how to reattach it. There is this little sliding mechanism thing that would have to be removed and then screwed in but for the life of my i cant remove it. Anyone ever reattach this item back up to the A pillar HELLLLLLLLLLLLPPPPPPP haha. It just getting annoying seeing it flapping around a bit. Thanks for any help
Luke Burt
Reg: 08-2007
Thursday, April 17, 2008 - 12:06 pm, by:  Luke Burt (Burt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not sure what your problem is David. Those handles simply clip onto the 'sliding mechanisms' they are attached to the A pillar with big screws, from memory. All you need to do is screw both of the sliding mechs onto your A pillar, then slide the handle over it and pull it away from the A pillar, this should clip the handle in place.
Adam Lonergan
UZZ32 #369 (V8)
Thursday, April 17, 2008 - 01:30 pm, by:  Adam Lonergan (Alchemistal) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
A pillar will have two black plastic lugs still attached. As far as I remember both ends of the handle slip onto the lugs from the top downwards.
David Grab
T78
Reg: 01-2008
Friday, April 18, 2008 - 12:53 pm, by:  David Grab (Blastedbyasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The problem is getting a plstic lug on the bottom out of the handle. Thats what i cant get out. After that its just a matter of screwing it in and putting the lug back into the handle. Hope that clears up things
Adam Lonergan
UZZ32 #369 (V8)
Friday, April 18, 2008 - 02:43 pm, by:  Adam Lonergan (Alchemistal) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
A picture speaks a thousand words.
David Grab
T78
Reg: 01-2008
Saturday, April 19, 2008 - 03:42 pm, by:  David Grab (Blastedbyasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah ill post them up soon, had a few snaps for this thread but to busy/lazy to get them off the camera haha
Dave Billings
Louisiana
SC 300, 2JZE, 5 Speed
Reg: 06-2007
Sunday, April 20, 2008 - 12:16 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
We call that the "oh sh!t" handle.
Gavin Smith
2.4 TD
Reg: 01-2008
Sunday, April 20, 2008 - 07:07 pm, by:  Gavin Smith (Gavs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dave Billings wrote on Sunday, April 20, 2008 - 12:16 am:
In my house, it's the "Jesus Bar"
