  SoarerCentral * General Soarer Chat * Single VS Twin Previous Previous    Next Next
Mohamad Zeed
2.5GT-T Soarer
Reg: 04-2007
Sunday, April 20, 2008 - 08:25 pm, by:  Mohamad Zeed (Nd4sp) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Now I'm not sure if this is in the right place.
The time has come for me to start modifying my engine. Now I have a TT and what I plan to do is get a front mount, pod, BOV, turbo back exhaust, Wolf 3d ecu and finally upgrade the turbos.
Now my question to you guys is, do you think I should convert to a single turbo or just upgrade the twin turbos?
What do you think...
Sunday, April 20, 2008 - 09:37 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
This has been covered many times over..... Search is your friend :-)
Adrain Parsons
JZZ30 tt
Sunday, April 20, 2008 - 10:00 pm, by:  Adrain Parsons (Ace1975) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
it all depends on your budget and the power you wish to get. allow $5000 for a good single set up.or $2500-$3000 for high flowed steel singles.
Aaron Grenadier
Reg: 04-2007
Monday, April 21, 2008 - 11:23 am, by:  Aaron Grenadier (Blue_sleeper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
To simplify it, it comes down to the torque versus power argument and which one you really want then make your decision from there.
Steven Anderson
UZZ31 Manual
Reg: 05-2006
Monday, April 21, 2008 - 11:57 am, by:  Steven Anderson (Cusscuss) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Aaron Grenadier wrote on Monday, April 21, 2008 - 11:23 am:
errr, no. Please go learn about the relationship between torque and power more.
Power = usable torque (for going fast), if you have power you have torque (including gearing, because cars do have gears)
