  SoarerCentral * General Soarer Chat * How Much For My Car You Rekon???? Previous Previous    Next Next
Kim Hunt
Supercharged SC400\Soarer GT-L UZZ31
Reg: 08-2007
Monday, June 02, 2008 - 06:02 pm, by:  Kim Hunt (Lxtasi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi guys i'm just posting to check how much i should put on the sale of my car. there is no reason other than the rising petrol prices means that i don't get to drive it as much as i would like. please help me out so i can get a good figure.
ok well her is the list i have compiled. its not edited and not complete. but just from this and some pics i would like to know..
UZZ31 1991 model V8 LTD Automatic 75 3xx kms
Custom supercharger manifold
RR fuel regulator
Rebuild Ford Thunderbird Eaton M90 with bypass valve running 10PSI
W2A intercooler
Custom W2A intercooler cooling system
Demon style head lights
6000k H.I.D head lights
Transmission oil cooler
Torsen LSD
Oil catch can
Custom master cylinder stopper
Custom intercooler piping
Custom intake box with pod
TEMS suspension with after market height controller
Remote central locking with immobiliser
DVD player in glove box, hooked up to the EMV
Thermo fans on Trans cooler and W2A “radiator”
10inch pioneer free to air sub in original sub space
Battery to boot relocation
Front and rear lips, with side skirts
2 ½ inch cat back exhaust with custom x pipe and stainless steel mufflers to 5 inch tips
ENGINE:
New plugs
New timing belt
New water pump
New tensioner and idler pulleys
Oil changed every 5000k’s
New oil Trans fluid/ flush
New power steering fluid/ flush
Power steering cooler
Custom supercharger install
Over 200rwkw/ 0ver 268rwhp
315cc green top supra injectors
New tires
12 months rego
Re-gassed air con
car has been well looked after
i love this car
thanks
kim
Kim Hunt
Reg: 08-2007
Monday, June 02, 2008 - 06:12 pm, by:  Kim Hunt (Lxtasi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
here are the pictures
thanks
Soarer Limited UZZ31 & Soarer 3.0GT JZZ31
Monday, June 02, 2008 - 07:08 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Personally, after adding up in general the cost of the car, and all the modifications done....
Id say you would be ideally asking in the upper 15-20k Mark. I see that its a realistic value.
Alone your car in tidy as it is condition would be at least 10-14k perhaps.
Alex Barbieri
Reg: 08-2007
Monday, June 02, 2008 - 07:45 pm, by:  Alex Barbieri (Barbieros) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That looks stunning. I want your car.
Blake Davies
S A
Factory 5sp TT
Monday, June 02, 2008 - 08:12 pm, by:  Blake Davies (Boss_da_man) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nice..
Kim Hunt
Reg: 08-2007
Monday, June 02, 2008 - 10:37 pm, by:  Kim Hunt (Lxtasi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
its for sale
Alex Barbieri
Reg: 08-2007
Tuesday, June 03, 2008 - 07:09 am, by:  Alex Barbieri (Barbieros) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well I could swap you a near stock 31 plus cash, but I think that misses the point of your sale altogether.
Kim Hunt
Reg: 08-2007
Tuesday, June 03, 2008 - 05:36 pm, by:  Kim Hunt (Lxtasi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sorry buddy. if it was a turbo 6 i might think bout it. your car looks good though
David Goldthorpe
UZZ31 GT-L
Reg: 11-2007
Tuesday, June 03, 2008 - 08:47 pm, by:  David Goldthorpe (Sprocket82) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Great car Kim. Did you do all the mods yourself? Just seems strange someone would put the time and money into supercharging a car and then sell it because of fuel prices.
Kim Hunt
Reg: 08-2007
Tuesday, June 03, 2008 - 11:43 pm, by:  Kim Hunt (Lxtasi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeh i have done most the mods. yeh well i have been feeling the fuel bill but its not just that. i would love to continue on the project like put a manual in it and an after market computer but i have been interested in the 1jz engine for a while now and want to see what i can do with them. so looking into buying a good tt soarer and start having fun building a turbo car. plus from the money i don't spend on the tt i will prob buy a little cheap run round car . i makes sense to me
Wednesday, June 04, 2008 - 12:53 am, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Kim Hunt wrote on Tuesday, June 03, 2008 - 11:43 pm:
SOmetimes its better the devil you know, than the one you dont....
TT's are cheap, but some are cheap for a reason you know.... I can understand the want to play with a TT though, as you cant beat bang for buck! Spend under $2500 on a TT and you will make over 200rwkw easy and run easy mid-low 13 second 1/4's... impossible to do on a v8. And the TT aint too bad on fuel... Depends on your right foot though! Hehe
Prayag Sharma
vic
single turbo soarer
Reg: 08-2007
Wednesday, June 04, 2008 - 01:28 am, by:  Prayag Sharma (Prayag) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
nice mate-
ask $11-15k on it
94 UZZ31 (V8) / 96 JZZ30 (TT) / 97 JZA80 (TT)
Wednesday, June 04, 2008 - 09:19 am, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'd put a tag of $15,000 on that, with that list of mods. Plus the interior seems to be in decent condition. Get in on the group buy of the floor mats mate, they're a great upgrade to the interior.
May want to take off the green P plates when you advertise the car though...
Wednesday, June 04, 2008 - 03:47 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Forgot to mention,lol..
I'd start at $15k and see how you go..
Yeah im with Vinh. ALways remove P plates from cars when taking pics for sales... Most people think " P plate " Been Thrashed!
And nows a good time NOT to link any vids :-)
Kim Hunt
Reg: 08-2007
Wednesday, June 04, 2008 - 05:47 pm, by:  Kim Hunt (Lxtasi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeh i put it the for sale forum for 19k but want to delete it.
yeh ill prob start round 15-16k seems reasonable. i will take the p plates off for some new pics. sucks how people have that mentality. thought they might think differently with a UZZ31. also thought they might run it through their heads why would i go to all the trouble of doing all the mods to just go thrash the car. oh well.
very keen on a tt. if they find a vid on it then i hope they will just say WEAPON and think how tuff it must be.haha.
should be putting it on car sales on the weekend all we shall see how it goes.
i say i wont miss it if i have a tt to play with but i know i will. extremely hard to part with a car that you have built up and know basically every part of it.
thanks guys
Sean Routledge
V6 Ecotec
Reg: 07-2008
Friday, July 11, 2008 - 12:01 pm, by:  Sean Routledge (Stircrazy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
have you done a quarter run?
