  SoarerCentral * General Soarer Chat * Baby seat anchor point Previous Previous    Next Next
Brett Hirst
Reg: 06-2008
Tuesday, June 24, 2008 - 04:32 pm, by:  Brett Hirst (Brettski) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can anyone tell me where the Baby seat anchor point is in my 1992TT soarer?
Mark Zimmer
Reg: 05-2008
Tuesday, June 24, 2008 - 05:03 pm, by:  Mark Zimmer (Markzimmer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mine came with them next too the air filters/sub on my shelf. But im not sure if it was put on later or not.
Scott Gates
Tuesday, June 24, 2008 - 05:36 pm, by:  Scott Gates (Scotty_001) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I know mine were put on during compliance, and same place near the speakers.
John Khanh
UZZ31 V8
Tuesday, June 24, 2008 - 08:02 pm, by:  John Khanh (Bigjohn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yep, behind the rear headrests near the speakers. Had a baby seat in there without any dramas. Only when she got older - she kept kicking the driver's seat. The passenger's side was for her older sister.
Back in AUS ! WOO !
XTR T-66
Tuesday, June 24, 2008 - 08:36 pm, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They are SUPPOSED to be installed when the car is complied.
Brett Hirst
Reg: 06-2008
Tuesday, June 24, 2008 - 08:38 pm, by:  Brett Hirst (Brettski) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for the reply! I had a look there on the weekend but couldnt seem to see anything. Im assuming I have to remove the parcel shelf to get to the point mentioned. If that is the case, do i remove the back seat to remove the parcel shelf?
Mercedes Benz SLK230 Kompressor
Wednesday, June 25, 2008 - 04:20 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Brett Hirst wrote on Tuesday, June 24, 2008 - 08:38 pm:
Yes.
Wednesday, June 25, 2008 - 04:44 pm, by:  Mike Triggs (Mikeandimah) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Brett, ours was a Private Import and didn't have them fitted. The rego inspector said I had to have them, then the mechanic here who inspected said he didn't care whether fitted ot not. The upshot is though that you have to have them fitted by a licenced person (the fitter put a sticker under our bonnet- they mainly do extra seats and the like).
I'd therefore advise not to do it yourself. It was a pretty fiddley job.
