  SoarerCentral * General Soarer Chat * Turning lights (i.e. fog lights to some) on lower front bar. HELP! Previous Previous    Next Next
Blake Davies
S A
Factory 5sp TT
Thursday, June 26, 2008 - 09:36 pm, by:  Blake Davies (Boss_da_man) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm looking for the glode/plug that goes into this light (as seen in photo)
http://i299.photobucket.com/albums/mm294/SenK9/PICT1496.jpg
Can anybody help?
What is the item number?
Friday, June 27, 2008 - 06:35 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Most likely an H2.
Damian Ware
UZZ32
Friday, June 27, 2008 - 08:34 am, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Turning lights are a bayonet style globe the same as the tail lights globes. There is a 50W philips globe that is a perfect fit and gives a little extra light.
The 94 onwards are fog lights used H3.
Blake Davies
S A
Factory 5sp TT
Friday, June 27, 2008 - 02:20 pm, by:  Blake Davies (Boss_da_man) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for your help...
