  SoarerCentral * General Soarer Chat * Fuel Capacity Q Previous Previous    Next Next
Prem Ananth Ganesh
Kuala Lumpur
Soarer (MZ10) & (JZZ30)
Reg: 11-2006
Friday, September 19, 2008 - 10:51 am, by:  Prem Ananth Ganesh (Soarerlover) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys.....can anyone tell me whats the total fuel capacity of a JZZ30 1992'? Someone told me its 80 Litres...is it true?
Thanks
Aaron Casey
Friday, September 19, 2008 - 10:54 am, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yep
Prem Ananth Ganesh
Kuala Lumpur
Reg: 11-2006
Friday, September 19, 2008 - 10:57 am, by:  Prem Ananth Ganesh (Soarerlover) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Really?...wow...thats huge man...
TR44i
Friday, September 19, 2008 - 12:22 pm, by:  Maurice Diggler (Mau_rice) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think it's 78L tank, I did know but aren't 100% sure, it's either 76L or 78L, the same size tank in all 30 series Soarers.
Friday, September 19, 2008 - 01:11 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
78 Litre tank and probably a bit more than another litre up to the spout.
Prem Ananth Ganesh
Kuala Lumpur
Reg: 11-2006
Friday, September 19, 2008 - 01:17 pm, by:  Prem Ananth Ganesh (Soarerlover) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
oh ok...thanks mate...since my fuel gauge is not working.......i have to keep my eyes on the odometer/trip to check whats the balance fuel i have and never tested to what extent it goes.
Mark Zimmer
Reg: 05-2008
Friday, September 19, 2008 - 04:50 pm, by:  Mark Zimmer (Markzimmer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yer 78-80 sounds right. Your fuel gauge isnt working :-O that would be a pain seeing because if you drive hard the soarers can drink like a camel.
Prem Ananth Ganesh
Kuala Lumpur
Reg: 11-2006
Friday, September 19, 2008 - 04:56 pm, by:  Prem Ananth Ganesh (Soarerlover) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
oh yes ....they do...fuel gauge isn't working...tried cleaning the senders....no result....i tried changing the dashboard meter...not working too...one guy suggested to change the sender and meter together...and that would cost a bomb....maybe just need to add in an external fuel gauge from other cars or aftermarket gauges.
Blake Davies
S A
Factory 5sp TT
Friday, September 19, 2008 - 06:20 pm, by:  Blake Davies (Boss_da_man) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
its has a 78L tank.
I have fill it from 68L to 78L (use 10L) and its full.
Friday, September 19, 2008 - 07:36 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Possible dash/guage mis-match?
TR44i
Friday, September 19, 2008 - 09:20 pm, by:  Maurice Diggler (Mau_rice) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Prem Ananth Ganesh wrote on Friday, September 19, 2008 - 04:56 pm:
Just buy another one from a wrecker, then clean it thoroughly before installation and you should be right for another few years.
Prem Ananth Ganesh
Kuala Lumpur
Reg: 11-2006
Saturday, September 20, 2008 - 02:39 pm, by:  Prem Ananth Ganesh (Soarerlover) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
well...in malaysia we dont get much soarer wrecks....even if there is..we only get the front cuts.....i guess i need to change the meters first and see. thanks
Saturday, September 20, 2008 - 06:01 pm, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maurice Diggler wrote on Friday, September 19, 2008 - 12:22 pm:
Except the JZZ31, which is only 70 litres.
Mercedes Benz SLK230 Kompressor
Sunday, September 21, 2008 - 09:37 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matthew is correct. JZZ31's from 9/97 - 12/2000 had a 68L tank.
ALL other 30 series Soarers have the 78L tank from 91 - 2000.
Monday, September 22, 2008 - 07:28 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Still enough to get me to Wellington with a bit to spare though =)
Prem Ananth Ganesh
Kuala Lumpur
Reg: 11-2006
Monday, September 22, 2008 - 10:53 am, by:  Prem Ananth Ganesh (Soarerlover) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
with the current fuel price in Malaysia....RM2.55....it will cost about RM200 for a full tank....and probably gives me around 600KM....
Anyway...do you think there would be a sender-meter mismatch....?
Brian Timms
TT Soarer Goodness.
Reg: 12-2006
Tuesday, September 23, 2008 - 07:13 pm, by:  Brian Timms (Turbo_brian) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don Bagnall wrote on Sunday, September 21, 2008 - 09:37 am:
Not what this one says...
http://www.cars-directory.net/specs/toyota/soarer/1999_8/5866/
Not everything on the internet is accurate though.
B.
Tuesday, September 23, 2008 - 09:14 pm, by:  Mike Triggs (Mikeandimah) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Prem Ananth Ganesh wrote on Monday, September 22, 2008 - 10:53 am:
Mate, 95 octane is the equivalent of RM5.40 here! Can't get 98 locally.
Prem Ananth Ganesh
Kuala Lumpur
Reg: 11-2006
Tuesday, September 23, 2008 - 09:24 pm, by:  Prem Ananth Ganesh (Soarerlover) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ya...but we are a net exporter of high grade petroleum...it was at RM1.92.....suddenly shot up to RM2.70 and now at RM2.55...and the gov just announced that they are bringing it further down...keeping my fingers crossed.
Tuesday, September 23, 2008 - 10:29 pm, by:  Mike Triggs (Mikeandimah) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm curious about 68 litres for our car as I filled the other day when the fuel gauge hit half and it took 40.75 litres. I know fuel gauges are usually inaccurate, but on Norfolk I let it run down to quarter and less at times (we were never more than 2 litres from a fill) and it usually took about 55-58 litres. Never once saw the fuel light come on in the '97 although it did a couple of times on the '95.
One thing I've noticed with the later Soarer is that when we don't use it much the economy really drops (like 5-5.5km/litre) and I wonder if it's not evaporating. Here we go 3 months without filling...
Brian Timms
TT Soarer Goodness.
Reg: 12-2006
Wednesday, September 24, 2008 - 06:57 pm, by:  Brian Timms (Turbo_brian) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
you know unleaded fuels start to 'go off' after about a month.....
B.
Wednesday, September 24, 2008 - 10:22 pm, by:  Mike Triggs (Mikeandimah) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Brian Timms wrote on Wednesday, September 24, 2008 - 06:57 pm:
Yeah... we had a Levin on Norfolk in 2000, with the 20v 4AGE engine. Went away on holidays, came back in a month or so, the car pinged like crazy just getting out of the drive. Was OK after I topped it up with fresh fuel.
By 2004 all unleaded to Norfolk was HULP although don't know the octane.
We can't get 98 here so when I go to Carnarvon I fill up jerries of it.
Prem Ananth Ganesh
Kuala Lumpur
Reg: 11-2006
Thursday, September 25, 2008 - 09:35 am, by:  Prem Ananth Ganesh (Soarerlover) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
As expected the fuel price is down by another 10 cents per litre....now its RM2.45 per litre. Hope it goes down further. :-)
Glen Muller
V8 Soarer UZZ31
Reg: 12-2007
Thursday, September 25, 2008 - 02:30 pm, by:  Glen Muller (Doom_and_gloom) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
When I had old fuel in my GSX750 it backfired like a bitch... awesome crackles when you're slowing down in low gears, complete with 6 inch flames from the Yoshi pipe... I miss that thing.
Friday, September 26, 2008 - 11:25 am, by:  Mike Triggs (Mikeandimah) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Glen Muller wrote on Thursday, September 25, 2008 - 02:30 pm:
I once had a Yamaha XS750 triple in which I installed a Wiseco 850 kit. The electric start wouldn't turn over and it pinged badly on hills no matter what octane boosters I put in it (using leaded fuel!). Probably should have retarded the ignition a tad.
Funnily enough I saw the bike about 12 years after I sold it, in a shed on Norfolk Island:-)
