  SoarerCentral * General Soarer Chat * 9 Second Soarer update Previous Previous    Next Next
Chris Threadgill
IL
SC300
Friday, November 11, 2005 - 04:48 am, by:  Chris Threadgill (Trbo_sc3) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Guys,
Just wanted to give you a quick update. Some of you may have heard the car popped the motor my last time out at the track. So I thought I would show you the stock internals and the amazing pieces Toyota put in our motors. I would imagine they didn't break because of the heat, causing them to bend instead of snap ;) It just amazes me these rods took many many dyno pulls and track passes.
[img]
http://www.clublexus.com/gallery/data/500/medium/Picture_0411.jpg[/img]
I'll be building the motor over the winter and coming out stronger than ever in the spring!
Chris
JZZ30 Twin Turbo
Friday, November 11, 2005 - 11:12 am, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
We're all looking forward to the flat 9 pass Chris :-)
Cheers and good luck with the rebuild,
Cihan.
Jeff Hogan
Friday, November 11, 2005 - 11:30 am, by:  Jeff Hogan (Hoges) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
wow thats pretty impressive to bend the rod like that! how much power was it running? have you got a link to any more pics and info about the car, i havent heard anything about it before and would love to see more!
Gotta love that toyota engineering! try doing that to a nissan engine and see how far out the driveway you get before it gives up the ghost lol
1991 UZZ30 GT4.0 V8
Friday, November 11, 2005 - 03:54 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Chris,
Many thanks for the update. If you could keep us posted as you progress, that would be MUCH appreciated.
What I find VERY impressive about your car Chris, is that it's still a "Normal" street driven SC300, yet is able to put down VERY,VERY fast times.
A credit to the driver, as well as the car
I think, that with your abilities an 8 sec time is possibly on the cards
Jeff Hogan
Friday, November 11, 2005 - 07:36 pm, by:  Jeff Hogan (Hoges) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I just found this thread from the clublexus page, that is one crazy soarer!!! check out the vid of him running a
9.59@143mph all with a completly stock 2JZ-GTE save for a set of cams!!! insanity!!
Chris, how long did the stock engine last at that power?http://www.clublexus.com/forums/showthread.php?t=181681&page=1&pp=15
Shane McInnes
Saturday, November 12, 2005 - 10:29 am, by:  Shane McInnes (Soarin_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jeff this was posted on this forum a few wks back now... you musta missed it. in the thread Chris put some pics up and the mods he has done.
and your right it is one crazy soarer.
Chris goodluck with the rebuild i hope you get into the 8's.
